Projectile question about rifles
  • Thread starter Thread starter csharsha
    Projectile
The discussion focuses on a physics problem involving projectile motion, specifically how a bullet fired horizontally from a rifle strikes a target at different distances. Initially, when fired at a range of 25 meters, the bullet hits 5.0 mm below the target. When the target is moved to 50 meters, the new vertical displacement can be calculated using the principles of projectile motion. Key equations include the horizontal range formula, which is relevant for determining the time of flight and subsequent vertical drop due to gravity.
  • Understanding of projectile motion principles
  • Familiarity with the equations of motion under gravity
  • Knowledge of horizontal range calculations
  • Basic algebra for solving equations
  • Calculate the time of flight for a bullet traveling 25 m and 50 m using kinematic equations
  • Explore the effects of gravity on projectile motion in different scenarios
  • Learn about the concept of air resistance and its impact on projectile trajectories
  • Investigate the principles of velocity selectors and their applications in physics
Students studying physics, particularly those focusing on mechanics and projectile motion, as well as educators looking for examples of real-world applications of these concepts.
csharsha
When a rifle is fired horizontally at a target P on a screen at a range of 25 m, the bullet strikes the screen at a point 5.0 mm below P. The screen is now moved to a distance of 50 m and the rifle again fired horizontally at P in its new position.
Assuming that air resistance may be neglected, what is the new distance below P at which the screen would now be struck?
Horizontal Range = (u^2sin(2w))/g
All the rest simple equations.
I seriously cannot do this question, I would put my attempt if I could.
Also, if someone could help me out with this. In a velocity selector, is a particle traveling in y-direction having acceleration? And is the x-component of the velocity constant?
Thanks!
Thanks!
If you drop the bullet out of your hand, how long does it take to fall 5mm?
What is the ratio of the time it takes the rifle bullet to travel 25m versus 50m?
28K
