Probabilities involving Mins and Maxes
  • Context: Undergrad
  • Thread starter Thread starter muzihc
    Probabilities
The discussion revolves around the probabilities associated with the minimum and maximum of two random variables, specifically exploring the expressions for P(Min(X, Y) < 1) and P(Max(X, Y) < 1). Participants are examining theoretical aspects of probability, particularly in the context of independent random variables.
  • One participant states that P(Max(X, Y) < 1) = P(X < 1)P(Y < 1) for independent random variables.
  • Another participant questions whether P(Min(X, Y) < 1) could equal P(X < 1) + P(Y < 1), suggesting a potential misunderstanding of the union of events.
  • A participant mentions the formula for P(A or B) = P(A U B) and indicates that the minimum case does not follow the same intuitive logic as the maximum case.
  • One participant proposes using the expression P(Min(X, Y) < t) = 1 - P(Min(X, Y) >= t) and assumes it leads to 1 - P(X >= t)P(Y >= t).
  • Another participant agrees with the previous point and elaborates on the relationship between the probabilities of the events A and B, suggesting a formula involving their intersection.
  • Several participants recommend studying order statistics to better understand the distribution of minimum and maximum values in samples of random variables.
Participants express differing views on the correct expression for P(Min(X, Y) < 1), with some proposing additive relationships and others suggesting a more complex formulation. The discussion remains unresolved with multiple competing views on the topic.
Participants reference the need for understanding order statistics to tackle more complex scenarios involving minimum and maximum values, indicating a potential gap in knowledge regarding this topic.
muzihc
I know for sure that P(Max(X, Y) < 1) = P(X < 1)P(Y < 1) if the two RVs are independent, but what does P(Min(X, Y) < 1) equal?
Would it be P(Min(X, Y) < 1) = P(X < 1) + P(Y < 1)?
Thanks
The probability of "X < 1 or Y < 1" involves the union of two sets. Have you sudied the formula for [itex]P(A \cup B)[/itex] ?
Thanks
Hey muzihc and welcome to the forums.
Have you ever come across order statistics?
http://en.wikipedia.org/wiki/Order_statistic
Hi,
I've studied P(A or B) = P(A U B) - I had a class in probability/statistics. I've never formally studied order statistics, though maybe I've overlapped with it at some point.
The maximum case is kind of intuitive - if the max is less than t, everything else is. We can treat it as P(A and B), in the independent case. On the other hand, if the minimum is less than t, the other random variable isn't necessarily.
I guess we could use P(Min(X, Y) < t) = 1 - P(Min(X, Y) >= t), in which case I assume it's 1 - P(X >= t)P(Y >= t).
muzihc said:
Hi,
Hey muzihc.
Take a look at order statistics. Order statistics helps you calculate the distribution of the minimum and maximum of a value given the number of samples that you have. It will help you in the first part of your question.
Let [itex]A =[/itex] the events where X < t [/itex]
Let [itex]B =[/itex] the events where Y < t [/itex]
[itex]P(A \cup B) = P(A) + P(B) - P(A \cap B)[/itex]
So for independent events [itex]A[/itex] and [itex]B[/itex]
[itex]P(A \cup B) = P(A) + P(B) - P(A) P(B)[/itex]
I agree.
[itex]1 - (1 - P(A)) (1-P(B)) = 1 - (1 - P(A) - P(B) + P(A)P(B)) = P(A) + P(B) - P(A)P(B)[/itex]
As chiro says, "order statistics" are the topic you should study if you want to tackle more complicated versions of the situation. For example: "In a sample of 4 values drawn from 4 independent random variables A,B,C,D, what is the probability that the second largest value is less than 1?"
