Find Spring Constant for Mass-Spring System
  • Thread starter Thread starter ccbb
    Spring
The spring constant for a mass-spring system involving a 25 kg mass compressing a spring by 2.5 m with an initial velocity of 10 m/s is calculated to be -98 N/m. This value is derived using the formula F = -kx, where F is the force exerted by the mass due to gravity (245 N). The velocity of the object upon rebounding to the spring's equilibrium position is determined to be 9.9 m/s, utilizing the conservation of energy principle, equating initial kinetic energy to the potential energy stored in the spring.
  • Understanding of Newton's laws of motion
  • Familiarity with energy conservation principles
  • Knowledge of spring mechanics and Hooke's Law
  • Basic algebra for solving equations
  • Study the derivation and applications of Hooke's Law in various systems
  • Explore energy conservation in mechanical systems, focusing on kinetic and potential energy
  • Learn about friction's impact on energy transfer in mass-spring systems
  • Investigate advanced spring dynamics in oscillatory motion
Students studying physics, particularly those focusing on mechanics, engineers working with mechanical systems, and anyone interested in the dynamics of mass-spring systems.
ccbb
I have a homework problem where a mass of 25kg hits a spring with a velocity of 10 m/s and compresses the spring 2.5m. The coefficient of friction between the object and the surface is .2. If someone could give me the starting point in finding the spring constant, and what velocity the object will have when the spring rebounds back to the equilibrium postion
I'm assuming you are dealing with a horizontal spring. Usually problems like these are best approached from an energy transfer perspective. Before the object hits the spring, the total energy in the system is just its kinetic energy, [itex]E_{K}[/itex]. Then as the spring compresses, how is the energy transfered? Remember the work done by friction. This formula might be useful for determining the spring constant:
[tex]E_{elastic~potential}=\frac{1}{2}kx^2[/tex]
where k is the spring constant, and x is the displacement from equilibrium.
To find the spring constant for this mass-spring system, we can use the equation F = -kx, where F is the force applied by the spring, k is the spring constant, and x is the displacement of the spring from its equilibrium position. In this case, the force applied by the spring is equal to the weight of the mass, which is 25kg multiplied by the acceleration due to gravity, which is 9.8 m/s^2. So we have F = (25kg)(9.8 m/s^2) = 245 N.
Next, we need to find the displacement of the spring, which is given as 2.5m. Now we can plug these values into the equation F = -kx and solve for the spring constant, k.
245 N = -k(2.5m)
k = -245 N / 2.5m = -98 N/m
So the spring constant for this mass-spring system is -98 N/m.
To find the velocity of the object when the spring rebounds back to its equilibrium position, we can use the conservation of energy principle. The initial kinetic energy of the object is equal to the final potential energy stored in the spring when it is compressed, so we have:
1/2 mv^2 = 1/2 kx^2
Where m is the mass of the object, v is the velocity, k is the spring constant, and x is the displacement of the spring from its equilibrium position.
Plugging in the values from the problem, we have:
1/2 (25kg)(10 m/s)^2 = 1/2 (-98 N/m)(2.5m)^2
Solving for v, we get:
v = 9.9 m/s
So the object will have a velocity of 9.9 m/s when the spring rebounds back to its equilibrium position.
I hope this helps guide you in solving your homework problem. Remember to always carefully consider the given information and use the appropriate equations to find the solution.
  • · Replies 17 ·
  • · Replies 58 ·
  • · Replies 17 ·
