Calculating Coefficient of Friction
The discussion revolves around calculating the coefficient of friction for a box weighing 325 N that is moving with constant velocity across a floor while being pushed with a force of 425 N at an angle of 35.2 degrees below horizontal. Participants are exploring the relationship between the forces acting on the box and how to derive the normal force.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of Newton's laws to establish that the net forces in both the x and y directions must equal zero due to the constant velocity. They explore resolving the applied force into its components and setting up equations to find the normal force and the coefficient of friction.
Several participants have provided insights into the setup of equations based on the forces acting on the box. There is a recognition of the importance of free-body diagrams, and some participants express confusion about the relationship between the normal force and gravitational force. The discussion appears to be productive, with participants clarifying concepts and terminology.
Participants are working under the constraints of a homework assignment with a test approaching, which may contribute to the urgency and need for clarification. There is an ongoing exploration of the definitions and roles of the forces involved, particularly the normal force.
listera
Help me! (mu K)
Will someone PLEASE explain to me how to find the coefficient of friction when given the following:
a box weighing 325 N moving with constant velocity across a floor, and it is being pushed with a force of 425 N exerted downward at an angle of 35.2 degrees below horizontal.
No matter how many times it is explained to me, I can't get the proper equation for Fn. Help! (test Monday)
Ok, there is a constant velocity, so by Newton's First Law, there is no net force on it.
That means that, by Newton's Second Law, the two forces must be equal in magnitude in the direction of motion (let's call that the x-direction) and opposite in direction. The forces in the y-direction must be equal and opposite, too, as there is no acceleration in that direction as well.
Now, you are going to want to resolve that applied force vector first!
The magnitude of the force component in the x-direction is: 425 cos(35.2 deg).
The magnitude of the force component in the y-direction is: 425 sin(35.2 deg).
Now we're ready to set up two equations using Newton's Second Law...
F_x, net = 0 = 425 cos(35.2) - mu_k * N
F_y, net = 0 = N - mg - 425 sin(35.2)
Now just solve the second one for N (the normal force) and the first one for mu_k, then plug in for N.
Start by identifying all forces acting on the box. Then, since you know that the velocity is constant the net force on the box must be zero. So that means that:
(1) the sum of the x-components of the forces = 0
(2) the sum of the y-components of the forces = 0
Express that mathematically. You'll need to know about friction: the force of kinetic friction is given by [itex]f = \mu N[/itex], where N is the normal force. You should be able to solve for [itex]\mu[/itex].
Thanks a bunch!
(I didn't know that mg was subtracted from Fn!)
listera said:
Thanks a bunch!
Do you understand why it's subtracted ? This is important !
Also, I hope you're drawing free-body diagrams...
muchos gracias! You guys helped a lot; my thanks to ya!
actually, i don't really know why it's subtracted... I tried looking it up, but in vain!
Have you drawn a free-body diagram ? What are all the forces in the y-direction ?
yeah I drew a body diagram...the forces I have in the y direction are the natural force and gravitational force.
What you call Fn (and I call N) stands for "normal" force, not natural force. "Normal" means perpendicular; the normal force between the floor and the box is the force that the floor exerts "normal" to the surfaces--that means straight up, in this case.
These are the forces acting on the box:
(1) weight = mg (acting down)
(2) N = normal force of the floor pushing up
(3) the applied force of 425 N (acting at a downward angle of 35.2 degrees below horizontal)
(4) the friction force of the floor against the box, f = [itex]\mu N[/itex] acting opposite to the direction of motion.
Note that the first three of these forces have components in the y direction.
hey thanks...i finally figured it out. (looking back...I found myself in a 'duh' moment there...) lol
  • · Replies 16 ·
