Electric field in an electrostatic precipitator.
Electric fields in electrostatic precipitators are crucial for removing pollutant particles from smoke in coal-burning power plants. The discussion centers on a specific setup involving a vertical hollow metal cylinder and a thin wire, with a potential difference of 50.0 kV established between them. The magnitude of the electric field midway between the wire and the cylinder wall was calculated to be approximately 96070.57 V/m, correcting an initial misunderstanding regarding the constancy of the electric field. The charge required for a 34.5 µg ash particle to experience a force ten times its weight was also addressed.
  • Understanding of electrostatics and electric fields
  • Familiarity with Gauss' Law
  • Knowledge of potential difference and electric potential
  • Basic calculus for integration
  • Study the application of Gauss' Law in cylindrical coordinates
  • Learn about the behavior of electric fields in non-uniform distributions
  • Explore the physics of electrostatic precipitators in industrial applications
  • Investigate the forces acting on charged particles in electric fields
Students studying physics, particularly in electrostatics, engineers working on pollution control technologies, and professionals involved in the design of electrostatic precipitators.
MSZShadow
Electrostatic precipitators use electric forces to remove pollutant particles from smoke, in particular in the smokestacks of coal-burning power plants. One form of precipitator consists of a vertical, hollow, metal cylinder with a thin wire, insulated from the cylinder, running along its axis . A large potential difference is established between the wire and the outer cylinder, with the wire at lower potential. This sets up a strong radial electric field directed inward. The field produces a region of ionized air near the wire. Smoke enters the precipitator at the bottom, ash and dust in it pick up electrons, and the charged pollutants are accelerated toward the outer cylinder wall by the electric field. Suppose the radius of the central wire is 83*10^(-6) m, the radius of the cylinder is 14.0 cm, and a potential difference of 50.0 kV is established between the wire and the cylinder. Also assume that the wire and cylinder are both very long in comparison to the cylinder radius.
A) What is the magnitude of the electric field midway between the wire and the cylinder wall?
B) What magnitude of charge must a 34.5*10^(-6) g ash particle have if the electric field computed in part (A) is to exert a force ten times the weight of the particle?
[tex]V_a - V_b = \int^{r_b}_{r_a}Edl[/tex]
[tex]F_{elec}=qE[/tex]
The first thing I recognized is that since V is directly proportional to l, if the distance l is halved, so will the potential V. So the V from a to b should be
[tex]V_{ab}=\frac{50*10^3}{2}=25*10^3[/tex]
Then I took the integral
[tex]V_a-V_b=\int^{r_b}_{r_a}Edl=E(l)^{r_b}_{r_a}=E(r_b-r_a)[/tex]
Then I solved for the magnitude of E at the specified point.
[tex]|E|=\frac{V_{ab}}{r_b-r_a}=\frac{25*10^3\ V}{(\frac{14*10^{-2}\ m-83*10^{-6}\ m}{2})-0\ m}=357354.7174\ \frac{V}{m}[/tex]
Of course, this is wrong. Where did I make a mistake, and how should I have done the problem?
It looks like you have assumed E is constant along the radius of the cylinder. I see others agree
http://answers.yahoo.com/question/index?qid=20100219162818AA3lXpY
but I don't understand that. The electric field lines spread out radially and are further apart at the outside than at the inside. It seems to me that means the electric field decreases with radius and therefore your integration is incorrect. Gauss' Law indicates the E field is proportional to 1/r.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elecyl.html#c2
You could integrate with E = C/r to get the C related to the potential difference and then you would know E as a function of r.
Ah. You're right. E wouldn't be constant...
That would mean that the graph of V against l wouldn't be linear as well...
Alright. I'll see where I can get with that. Starting with solving for the linear density...
Alright. Got it. The answer to part A is 96070.57423 V/m. Thanks. :)
  • · Replies 28 ·
  • · Replies 27 ·
