Blah Finding a relatinship between volume and a diagonal
  • Thread starter Thread starter Stevo11
    Volume
The relationship between the volume (V) of a cube and the length of its diagonal (d) can be established using the formula V = L^3, where L is the length of each side of the cube. For a cube, the diagonal can be calculated using the Pythagorean theorem applied twice, leading to the formula d = L√3. By substituting L = d/√3, the volume can be expressed as V = (d/√3)^3. Evaluating this for a diagonal length of d = 1.2 yields a volume of approximately 0.148 cubic units.
  • Understanding of basic geometry, specifically properties of cubes.
  • Familiarity with the Pythagorean theorem.
  • Knowledge of algebraic manipulation and exponentiation.
  • Basic calculus concepts (optional for deeper understanding).
  • Study the derivation of the diagonal formula for three-dimensional shapes.
  • Learn about volume calculations for different geometric solids.
  • Explore applications of the Pythagorean theorem in three dimensions.
  • Investigate the relationship between surface area and volume in geometric figures.
Students in mathematics, particularly those studying geometry and calculus, as well as educators looking for clear explanations of geometric relationships.
Stevo11
Find the relationship describing the volume (V) of a cube as a function of the length of the diagonal going through the cube (d). evaluate it for a diagonal length of d = 1.2.
I seriously don't know where to start, I'm taking Biology, but I have to take calculus as well and I'm seriously awful at math and have no clue how to start this problem :frown:
Look up the volume of a cube formula.
V=LWH, L=length, W=width, H=height
Now, note that this is a cube. In math when you read or hear words like cube, bells should be going off telling you that this implies that all the sides are going to be of equal distance.
So.
L=W=H
V=L^3
Now for the diagonal going through the cube, I'm going to assume that the line spans the maximum distance that it can inside the cube, from one corner to its opposite diagonal corner. For this distance you can use the Pythagorean theorem twice.
Once for a triangle that is flat on the floor with the longest side as the diagonal from corner to corner of the base of the square. The next will use the longest side of the previous triangle as the base and now the longest side of the new triangle will be the like the 3-D diagonal path of the line inside the cube. (it may take a few seconds to see this)
Call each side L and express the volume in terms of it after using the Pythagorean theorem twice. After you have that then plug in for L=1.2
11K
  • · Replies 33 ·
  • · Replies 41 ·
