Looking for a generic code using Mathematica
  • Context: Mathematica
  • Thread starter Thread starter kaizen.moto
    Code Mathematica
The discussion revolves around creating a generic code in Mathematica to express a series of mathematical functions involving products and sums of indexed variables. Participants explore different coding approaches and address issues related to warnings and the correct implementation of dot products.
  • Homework-related
  • One participant requests a generic code to express a series of functions defined by indexed variables.
  • Another participant proposes a code snippet using the Product and Sum functions to define the desired expressions.
  • A participant notes warnings encountered when running the code, specifically related to part specifications.
  • Concerns are raised about the difference between product and dot product in the output of the code.
  • Suggestions are made to change the implementation to use the Apply function with Dot to achieve the correct operation.
  • There is a discussion about the importance of meaningful variable names to avoid confusion in coding.
  • One participant emphasizes the necessity of testing the code with known examples to ensure correctness.
  • A participant expresses gratitude for the assistance received and reflects on their learning experience with Mathematica.
  • Another participant advises taking programming or numerical methods classes to improve coding skills.
Participants express varying levels of agreement on the coding approaches, with some suggesting modifications while others highlight unresolved warnings and issues. The discussion remains unresolved regarding the optimal implementation and the source of warnings.
Participants mention specific warnings related to part specifications and the need for clarity in variable naming conventions. There are indications of unresolved issues regarding the output format (product vs. dot product) and the effectiveness of the proposed solutions.
This discussion may be useful for Mathematica users, particularly those at a novice level seeking assistance with coding practices and troubleshooting common issues in mathematical programming.
kaizen.moto
Dear all,
Iam looking for a generic code that could express the following functions:
Subscript[mata, 1] = hl[[1]];
Subscript[mata, 2] = matg[[2]].hl[[1]] + hl[[2]];
Subscript[mata, 3] = matg[[3]].matg[[2]].hl[[1]]
+ matg[[3]].hl[[2]] + hl[[3]];
Subscript[mata, 4] =
matg[[4]].matg[[3]].matg[[2]].hl[[1]]
+ matg[[4]].matg[[3]].hl[[2]]
+ matg[[4]].hl[[3]]
+ hl[[4]];
Subscript[mata, 5] = matg[[5]].matg[[4]].matg[[3]].matg[[2]].hl[[1]]
+ matg[[5]].matg[[4]].matg[[3]].hl[[2]]
+ matg[[5]].matg[[4]].hl[[3]]
+ matg[[5]].hl[[4]]
+ hl[[5]];
Please help me to get the right code for the above expressions. It may looks like this:
Subsript[mata,i] = ... where i = 1,2,3,...17.
Thank you for any kind help.
term[n_Integer,m_Integer]:=Product[matg[],{i,m+1,n}] hl[[m]] /;(n>=m)
Subscript[mata,n_]:=Sum[term[n,i],{i,n}]
Hm, the concept is correct and works, however, there is minor warnings that I need to fix, warnings says:
' Part::partd:Part specification h1[[1]] is longer than depth of object.>>'
Thank you for your kind help
If you look at your original post and Dale's attempt to help you you see that there are multiple uses of hl (HL if I were to capitalize that to make it obvious), but no uses of h1 (H followed by the digit one to make it obvious) until you tried typing back in what he attempted to show you how to do. So I would start looking there.
Thank you for the comment, I found that the result of the given code shows the product rather than dot product. I mean after running the code, it gives me for instance
In[1]:= Subscript[mata, 4]
Out[1]:= matg[[4]] matg[[3]] matg[[2]] hl[[1]] + matg[[4]] matg[[3]] hl[[2]] + matg[[4]] hl[[3]] + hl[[4]];
Iam trying to figure out how to make it dot product as per original code shown before.
term[n_Integer,m_Integer]:=Apply[Dot, Table[matg[],{i,m+1,n}]].hl[[m]] /;(n>=m)
Thank you again for your help. It works now but I still can't figure out why I still got the warnings. I have tried many many ways to overcome the warnings but still failed including putting back the hl( hL) to h1 (h one).
Iam still wondering though why did you change from h1(h one) to h1 (hL).
One thing first semester students are taught in introductory programming classes, are not to name things like hl or h1 or matg or mata, but to instead use meaningful names that are not easily confused.
Carefully reading all your posts in this particular thread seems to show that no one but you has written h1 (HOne) in any message except the ones where I was pointing out what I thought the source of your error was.
As I've recommended to you at least once before, in the last year of your asking people to fix your problems you could easily have taken programming language classes and learned to avoid at least some of the problems that you struggle with month after month.
If you knew no mathematics you would not stumble along asking people to do your math for you, but you seem to consider learning programming skills to be exempt from this advice.
Have you tested the code on a known example to determine if it is giving you the correct result? If so then don't worry about the warning, if not, then you need to figure out a test case. I cannot overemphasize the importance of thouroughly testing each module. That is, in fact, one of the big reasons for splitting your code up into smaller modules, so that you can test each piece separately and isolate problems.
Dale, first of all, I wanted to say, you are a very nice person and very helpful. Iam very pleased with all your comments and advice from the beginning you helped me until now. You have given me the courage to learn to use mathematica in a such a way that makes me feel enthuastic towards learning mathematica. The way you gave me all the comments are very friendly and always make me happy to learn more and more each day. I just wish that you are awarded more medals than the two.
Secondly, I have no idea that this forum is only suitable for advanced level knowledge of mathematica and no room for posting from novice user of mathematica.
Thank you again for all your wonderful, fantastic guidance and commets.
I wish we could meet one day for a cuppa of coffee!
Thank you, but even if he irritates you I would seriously consider Bill Simpson's advice. He is a good programmer and offers consistently good suggestions. In particular, it would be very valuable for you to take a programming class, a numerical methods class, or both. Even if it isn't specifically in Mathematica there would be a lot of language-independent programming concepts that would translate.
