Find Min Distance for Train to Avoid Collision
  • Thread starter Thread starter ffrpg
    Minimum
The discussion revolves around two physics problems involving motion: the first concerns a train's braking distance to avoid a collision with a freight train, while the second involves a car's acceleration under constant power conditions. Participants are exploring the calculations and underlying principles related to these scenarios.
  • Mixed
  • Participants discuss the application of kinematic equations to determine the minimum distance for the train to avoid a collision, with some questioning the correctness of their calculations. The second problem prompts discussions on integrating differential equations related to acceleration and power, with participants expressing uncertainty about their approaches and the implications of constant power versus constant acceleration.
There are multiple interpretations of the problems being explored. Some participants have provided guidance on integrating equations and rethinking the setup of the problems. However, there is no explicit consensus on the correct approaches or solutions, as participants continue to question their methods and assumptions.
Participants are working under the constraints of homework rules, which may limit the information they can use or the methods they can apply. There is also a noted confusion regarding the definitions of acceleration in the context of constant power, as well as the parameters used in the calculations.
ffrpg
I know I've asked quite a few questions, but I really am making an effort to get as far as I can. The engineer of a train moving along a level track with a velocity of 42.0 m/s sights a freight train at a distance of d ahead of him on the same track moving in the same direction with a velocity of 18.0 m/s. He applies the brakes, giving his train a constant acceleration of -1.4 m/s^2. What is the minium distance d such that there is no collision?
Here's what I came up with. I used the formula d/delta x = 42.0t+1/2(-1.4)t^2. I derived the formula giving me 42+(-1.4)=18. Solved for t getting 17.143. Plugged t back into the original formula I used and ended up getting 514.288. That isn't the correct distance..
Here's another question..
Let's say that you are driving a car that accelerates according to a=B/v where B= 130.0m^2/s^3 is a parameter that is related to the ratio of your car's power to its weight, and c is your car's speed, in m/s. Assume that you are initially traveling with a speed of 11.5 m/s. At t=0 you step on the gas pedal. The car performs a constant-power acceleration until you reach a speed of 23.5 m/s. What is the time interval needed to make this change of speed.
I solved for a by plugging in the values given for B and v, so a=130.0m^2/s^3/11.5 m/s. I then got a= 11.3m/s^2. From there I went to 11.5+11.3t=23.5. Solved for t and got 1.062 s. 1.062s isn't the correct answer. Was my approach to this problem incorrect?
Your first question is equivalent with the following: how far does a stone go up (what height) if one throws it upwards with (42-18)m/s and the gravitational pull is g=1.4m/s2 (about the same as on the moon).
For the second one I have another advice for you: start thinking the problems "in letters" first and then plug in the numbers. You have a*v=B=constant (as the power remains constant at those 175 horse power it has). you also have a=dv/dt. So I now see a diiferential equation with separable variables v and t. Do you know how to solve this one?
Nope I still don't know how to solve it (the 2nd question). How did you figure out the car had 175 horse power? I don't think it matters. Are you saying I should integrate a=dv/dt?
Looks to me like you have done this correctly. you have x= 42.0t+ (1/2)(-1.4)t^2 (that's the distance the train goes in time t. I don't understand the "d/delta" part.) Differentiating (which in my opinion is better than "deriving") gives velocity and, of course, the train can avoid a collision by slowing to 18 m/s: dx/dt= 42.0- 1.4t= 18 (you left the t out in your formula. I hope that was a typo) which gives -1.4t= 18-42= -24 so t= -24/-1.4= 17.1 seconds precisely what you got. Now put that back into the formula for x: 42.0(17.1)+(1/2)(-1.4)(17.1)^2= 718.2-0.7(292.41)= 718.2-204.7= 513.5 m. Now, why do you say that is not the correct distance?
a= B/v is the same as dv/dt= Bv or dv/v= Bdt. Integrating both sides, ln|v|= Bt+ Const or v(t)= e^(Bt+ Const)= e^(Bt)e^Const= C e^(Bt) where C= e^Const. Since your initial speed is 11.5 m/s,
v(0)= C e^0= C= 11.5 so v(t)= 11.5 e^(Bt). Your car reaches 21.5 m/s when v(t)= 11.5 e^(Bt)= 21.5 or e^(Bt)= 21.5/11.5= 1.87. Now take the natural logarithm of both sides: Bt= ln(1.87). Since you know B you can now solve for t.
I figured the car weighs about 1000kg so power=B*1000Kg.
I'm saying you should do the following:
v*dv=B*dt
integrate: ∫11.523.5 dv*v= ∫0t' dt'*B
giving: (1/2)v2|11.523.5 = (23.52-11.52)/2 = B*t
HallsofIvy: it's a=B/v, not a=Bv. Man, this would be easy if we could use the latex &over
Oops! I switch the formula in mid-sentence!
You say, first, "you are driving a car that accelerates according to a=B/v" and then later say:"The car performs a constant-power acceleration" and seem to be assuming that means a constant acceleration. You calculate B/v for v= 11.4 m/s and then use that constant acceleration. I am inclined to interpret "constant power acceleration" as meaning that the acceleration follows the law you gave: dv/dt= B/v.
dv/dt= B/v gives vdv= Bdt so (1/2)v^2= Bt+ C. Your initial speed is 11.4 m/s so (1/2)(11.4)^2= C or C= 64.98. Your speed at any time t is given by v^2= 2Bt+ 129.96. You want to increase to 23.5 m/s so you need to solve 2Bt+ 129.96= 23.5^2= 16889.
  • · Replies 23 ·
