Finding the Derivative of an Inverse Function
  • Thread starter Thread starter UrbanXrisis
    Derivative Inverse
The discussion revolves around finding the derivative of an inverse function, specifically focusing on the function f(x) = x^2 and its inverse g(x) = f^-1(x) = x^(0.5). Participants are exploring the relationship between the derivatives of these functions and addressing confusion regarding the notation and calculations involved.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to derive g'(4) using the formula g'(y) = 1/f'(x) and are questioning the steps involved in finding the inverse function. There is also discussion about the acceptability of different notations and methods for expressing the derivative.
Some participants have provided calculations and expressed their understanding of the derivative of the inverse function. There is an ongoing exploration of the notation used and whether certain expressions are acceptable. No explicit consensus has been reached on the preferred method of notation.
Participants are considering the clarity of their expressions and the expectations of their instructor regarding notation and explicitness in their solutions. There is an acknowledgment of varying standards in academic settings.
UrbanXrisis
I was taught in class that if g(x) is f^-1(x), then g'(y)=1/f'(x)
my notes for an example:
f(x)=x^2
g(x)=f^-1(x)=x^(.5)
g’(4)=?
g(x)= x^(.5)
g’(x)=.5x^-.5
g’(4)=1/f’(x), x=4^(.5)
g’(4)=1/f'(2)=1/2*2=1/4
I have no clue how g(x)=f^-1(x)=x^(.5) and how g’(4)=1/f'(2)
I am just overall confused any help would be appreciated
f(x) = x^2
set f(x) = y
y = x^2
(*To find inverse solve for x explicitly in terms of y*)
y^0.5 = x
f^-1(x) = x^0.5
let g(x) = f^-1(x)
g(x) = x^0.5
The second one follows the same way
I have:
and also:
g'(4)=1/f'(x)=1/f'(2)=1/4
is both ways acceptable?
UrbanXrisis said:
I have:
and also:
I wouldn't go with the second one. It could be seen as wrong to say g'(4) = 1/f'(x) without saying what x is explicitly, which in this case is root(4).
But, it depends how picky your instructor is
what about:
g’(x)=.5x^-.5=.5(4)^-.5=1/4
could that be acceptable too?
UrbanXrisis said:
what about:
Sure,
g(x) = [tex]x^\frac{1}{2}[/tex]
thus,
g'(x) = [tex]\frac{1}{2x^\frac{1}{2}}[/tex]
g'(4) = [tex]\frac{1}{2*4^\frac{1}{2}}[/tex]
g'(4) = [tex]\frac{1}{2*2}[/tex]
g'(4) = [tex]\frac{1}{4}[/tex]
Again, I would just recommend that you specify you are changing from the general equation g'(x) to g'(4) somewhere in your solution. But if its not on a test, or your teacher isn't picky then that should be fine.
