Volume of Cone with Inscribed Sphere
  • Thread starter Thread starter zeion
    Cone Sphere
The problem involves a cone that is circumscribed around a sphere with a known radius. The task is to express the volume of the cone in terms of a variable x, which represents a segment of the cone's height. Participants are discussing the geometric relationships between the cone and the inscribed sphere.
  • Participants are attempting to relate the dimensions of the cone to the variable x, with one suggesting the use of Pythagorean theorem to find the radius of the cone. Others are questioning the choice of x as the main variable and discussing the implications of different angles at the cone's vertex.
The discussion is ongoing, with participants exploring various geometric interpretations and relationships. Some have provided insights into how to derive the necessary dimensions for calculating the volume, while others are still seeking clarity on how to express the volume in terms of x.
There is a diagram referenced that illustrates the relationship between the cone and the sphere, but specific details about the diagram are not provided. Participants are also considering the implications of choosing different angles for the cone's vertex.
zeion
A cone is circumscribed around a sphere. The radius of the sphere is 5 units.
Write the volume of the cone in terms of x.
There is a diagram.. I will try to describe it:
It is a cross section of the object (sphere in cone). From the center of the circle to the bottom left vertice of the triangle is length 5 + x. (5 is the radius, x is the rest of the line).
So I can get r of the cone with Pythagoras = sqrt((x + 5)^2 - 25). The height would be 10 + something. I'm not sure how the missing part of the height relates to x.
The problem is that there are an infinite number of such cones. First draw a triangle circumscribing a circle (the sphere inside the cone seen from the side). Choose and angle for the vertex at the top of the sphere. That angle cannot be 0 or 180 degrees but it can be any other between. And then there exist a cone, having that angle at the vertex, circumscribing the sphere.
So how can I write the volume in terms of x ?
I certainly wouldn't have chosen x as the main variable in this problem, but never mind that. Look at the figure. All you need to find the volume of the cone is its radius and height. So in the figure you need to get r and y in terms of x. r is easy from the right triangle AOB. Then you can get w + v in terms of y and x from triangle ABD. Then use the similarity of triangles ABD and DCO to get y in terms of x.
9K
