How to Solve Multi Phase Kinematics Problems?
The discussion focuses on solving multi-phase kinematics problems involving constant acceleration. The user is tasked with determining the duration of the first acceleration phase, the constant acceleration during this phase, and the constant negative acceleration during the second phase, given a total distance of 100 meters and a total time of 9.780 seconds. Key formulas provided include the displacement formula \( s = t \times \frac{(u + v)}{2} \), where \( s \) is displacement, \( u \) is initial velocity, \( v \) is final velocity, and \( t \) is time. The user is guided to set up a system of equations to solve for the unknowns.
  • Understanding of basic kinematics principles
  • Familiarity with the displacement formula \( s = t \times \frac{(u + v)}{2} \)
  • Ability to set up and solve systems of equations
  • Knowledge of constant acceleration motion
  • Study the derivation and application of the displacement formula in kinematics
  • Learn how to solve systems of equations in physics problems
  • Explore examples of multi-phase motion with constant acceleration
  • Review concepts of average velocity and its role in kinematics
Students studying physics, particularly those focusing on kinematics, as well as educators looking for examples of multi-phase motion problems and their solutions.
canadiankid
1. I have been given the total distance (100m) and the total time (9.780s) as well as a speed (11.7m/s) at t1 and a final speed (10.5m/s) at the end of the given time (9.780s). The initial velocity is zero at t=0. Acceleration is constant. I am not asking for the answer, just an algebra based formula or series of formulas to lead me in the right direction (question was on a midterm two years ago), since i do not have d, a or t for t1. I need to find:
a)What is the duration of the first acceleration phase? (t=0 to t1)
b)What is the constant acceleration during the first phase?
c)What is the constant negative acceleration during the second phase? (t1 to 9.780s)
Im not sure what any relevant equations are as I cannot find one that doesn't require at least two of a,d or t.
I calculated the average acceleration from t=0 to t=9.780s (a=20.4499m/s2) but that seems useless to me. I drew the acceleration, velocity (labelled this one) and position graphs to re-enforce the broader concept.
Thanks in advance for the help!
c)What is the constant negative acceleration during the second phase? (t1 to 9.780s)Im not sure what any relevant equations are as I cannot find one that doesn't require at least two of a,d or t.I calculated the average acceleration from t=0 to t=9.780s (a=20.4499m/s2) but that seems useless to me. I drew the acceleration, velocity (labelled this one) and position graphs to re-enforce the broader concept.
You need to make use of the formula s = t * (u+v)/2
Here
s = displacement (perhaps what you called d?)
u = initial velocity
v = final velocity
t = time
Translated to English that formula reads displacement equals time by average velocity.
For the first phase u = 0, v = 11.7, t = t1
For the second phase u = 11.7, v = 10.5, t = 9.78 - t1
The total of those two displacements = 100
This will enable you to solve for t1, and once you have that it should all be easy
Ah yes it is a system of equations... I always over think those. Thank you very much!
And yes I did you d for displacement, however you are more correct as d would represent distance, not displacement.
  • · Replies 20 ·
