| New Reply |
Calculate the heat capacity at constant volume and constant pressure. |
Share Thread | Thread Tools |
| Sep18-11, 11:20 PM | #1 |
I am given the amount of moles of gas, how many joules of heat I put into the system, and a positive change in temperature. Then it says "calculate the molar heat capacities at constant volume and constant pressure of the gas." 2. Relevant equations q=CT, C(constant pressure)-C(constant volume)=nR, U= q+w, H=U+PV 3. The attempt at a solution I just don't know how to do this problem without knowing whether the temperature change occurs at constant volume or constant pressure. If I knew either of those the problem would be easy. I have q and delta(T), so I should be able to calculate a heat capacity. But I don't know which one it would be. |
| Sep19-11, 03:18 AM | #2 |
Admin
Can you give exact wording of the question? Perhaps the information is there, just hidden?
| Sep19-11, 03:01 PM | #3 |
"When 178 J of energy is supplied as heat to 1.9 mol of gas molecules, the temperature of the sample increases by 2.55 K. Calculate the molar heat capacities at constant volume and constant pressure of the gas."
| Sep19-11, 04:04 PM | #4 |
Admin
Nah, you are right - question is unclear.
| Sep19-11, 04:23 PM | #5 |
| Sep20-11, 11:31 AM | #6 |
Well my professor is a senile old man so I tried to ask him today, but he seemed to have a mental block against admitting he wrote the question wrong so at first he tried to tell me I can assume the pressure is constant, then that I can assume that the volume is constant.
I guess I just have to hope that he doesn't pull this **** on the exam because he would probably just arbitrarily pick one that he wanted us to assume was constant and if I confronted him about it get the same talking in circles answer that I got just now. I hate college sometimes. |
| New Reply |
| Thread Tools | |
Similar Threads for: Calculate the heat capacity at constant volume and constant pressure.
| Derive heat capacity at constant pressure | Advanced Physics Homework | 2 | ||
| Heat capacity at constant volume | Introductory Physics Homework | 4 | ||
| Formulas for Molar Heat Capacity at Constant Pressure/Volume | Introductory Physics Homework | 1 | ||
| specific heat capacity at constant pressure | General Physics | 1 | ||
| Heat Capacity of Air at Constant Volume | Introductory Physics Homework | 10 | ||
