| View Poll Results: Is global warming a real threat? | |||
| Yes, It's due to our own actions. |
6 | 19.35% |
| Yes, but it's entirely natural. |
5 | 16.13% |
| Yes, it's a composite or natural and human factors. |
15 | 48.39% |
| No, its due to misleading figures and political spin. |
5 | 16.13% |
| Voters: 31. You may not vote on this poll | |||
| Thread Closed |
Global warming- Yes or no? |
Share Thread | Thread Tools |
| Nov18-04, 04:33 PM | #1 |
Since there seems to be a lot of controversy about this, I thought I'd do a little poll to collect the oppinions of you guys. Is global warming a real threat caused by us, a purely natural occurence or a cross between misleading figures and political spin?
Views & opinions appreciated. |
| Nov18-04, 05:30 PM | #2 |
Good initiative. A few remarks though before I vote.
The question actually is fourfold. A - Global warming is happening: True - depends - false B - Humans cause global warming: true- in between - false. C - Warming is a real and bad threat: Yes - depends - no. D - More carbon dioxide in the atmosphere is: good-in between- bad I think it is like this: A: Global warming is happening: Depends. There are a lot of cycles active. Global warming was happening somewhere between 1880 and 1940 and again between 1985 and 1998. Since then the warming has leveled of. Global cooling has happened between 1950 and 1980. B: Humans cause global warming: in between, to be honest, but certainly close to "false". Considering the logaritmic relationship between greenhouse gas concentration and effect, the increase in anthropogenic greenhouse gas effect is a minor factor. C - Warming is a real and bad threat: We have no clue whatsoever. Seeing the multiple cycles involved the temperature is bound to go down in the near future. If the warming would persist, catastrophic events like racing sealevel rise is still humbug, but even if it wasn't, there is virtually nothing we could do. D - More carbon dioxide in the atmosphere is: good. Definitely. The Greehouse gas effedct -as said- is minor and we even don't know if it is bad or good. But if we want to continue feeding the exploding world population, we need biomass, lot's of it. Carbon dioxide is the basic building stone of biomass. Tree rings in the last century have increased thickness in the last century, not because of warming but because of enhanced growing speed due to increased building stones. Furthermore, CO2 is radioactive due to cosmogenic radioactivity. Fossil fuels are depleted of radioactive carbon (14C) hence a higher CO2 level due to fossil fuels is healtier for the living creatures. |
| Nov19-04, 10:58 AM | #3 |
| Nov19-04, 12:04 PM | #4 |
Global warming- Yes or no?One thought I have on this is...yeah, extra CO2 means extra food for plants which could increase growth rates; however, carbon is probably not the "limiting factor" in plant growth (more likely to be nitrogen or phosphorous or some other nutrient needed by plants). In other words, in an excess of carbon, plant growth would not greatly increase unless the amount of other essential nutrients also increased. |
| Nov19-04, 12:33 PM | #5 |
That's the spin indeed Phobos. And it also shows how terrible the AGW lobby has to bend things that are right to be wrong.
[http://earthobservatory.nasa.gov/New...05169337.html] |
| Nov19-04, 01:09 PM | #6 |
I'm gonna have to disagree with you there Andre. Do artificial fertilisers always produce inferior results? Many farmers choose to use artificial fertiliser due to a number of reasons, including it having the specific nutrients nessecary for plant growth in readily avaliable forms, where as manure is as it comes out of the cow, and requires organic breakdown before plants can absorb anything. If natural fertilisers have any advantage over artificial ones, it is that they promote the development of a humus layer in the soil, which retains nutrients for plants to use, and improves soil texture significantly, where as an artificial fertiliser is often water soluable and washes away during any significant rainfall. Even if CO2 levels in the atmosphere (not CO2 levels reaching the plant itself, as matters are complicated by humidity levels, rates of diffusion and opening/closing of stomata) were a limiting factor, I think you would be hard pressed to find any noticable change in the CO2 levels above a manure fertilised field and an artificially fertilised one.
| Nov19-04, 01:54 PM | #7 |
Well that are all testable ideas I guess. It must have been done already. And if the soil is emitting carbon dioxide it still had to pass the leaves from below to up before it finally dillutes. What, if it was visible like smoke, would your intition still say that at the leafs height it would no longer be traceable?
Many plants thrive better if their crown is pruned, allowing for more air = CO2 to pass. Obviously the growing restriction is to little CO2 in the air. In Holland there are greenhouses that get the exhaust gasses of power plants directly. Oops...Stupid ... that is a secret to get the largest crops in the world. I didn't tell you that. Any idea why most stomata are at the bottom side of leafs? |
| Nov19-04, 02:49 PM | #8 |
For plants, other nutrient are a limiting factor. Some plants grow better when they form symbiotic relation with soil bacteria, such as Rhizobium. The bacteria fix nitrogen for plant. The yield of crops increases when bacteria are present. All the CO2 in the world, will not fix that.
Also, bacteria can be a problem. If the soil if fertilized and then flooded, the soil bacteria will eat up the plant nutrient and the soil will not be appropriate for the plant growth. New research is should that overfertilization is also causing problem with plant-microbe interaction. Several farm and crop management are pointed as the source of the problem. Also, will an increase in CO2 give advantage to all plant or just certain plants. You have to remember that plant are well adapted the environment as we known it and plant crops have receive several genetic modification. If only part of the plant kingdom is favor, will it be pest plants rather than plants that advantageous for the animal kingdom, especially human. The stromata are on the underside of the leaf because it allows the plant to reduce the amount loss to transpiration. If the stromata were on the topside the plant would lose too much water because the guard cells are light sensitive and open, in part, according to sunlight. |
| Nov20-04, 12:52 AM | #9 |
Experiments have shown that CO2 increases raise plant growth levels fairly equally across species. I could swear some one posted the link in this forums the past month or so. I don't have the Mozilla physicsforums.com searcher, maybe some one could try and find this for us? Though I do remember that a doubling of CO2 results in less than a doubling in plant carbon-intake (+70% ?). No surprise there, but significant.
This statement, however, Ocean acidity/marine life may be the largest environmental system affected by CO2 (on a short time scale) besides the atmosphere, but its not the only one. While I don't think 100 ppm CO2 increase will cause much global warming (at least not directly), that doesn't mean that CO2 is a 'good' thing by any means. Even if it does increase crop yields. |
| Nov20-04, 12:44 PM | #10 |
Pebrew, You said "strongly disagree". Now how could I reflect about this neutrally, when you polarlize yourself.
I guess by now it should be clear that there are always two sides to that kind of news as you have reflcected upon earlier. Actually four. Does the writer want to prove antropogenic global warmer or does he detest it? and who is funding the study, the enemy seeking leaders or the oil compagnies? The current CO2 content of the ocean is a order magnetude higher than the atmosphere. Doubling the CO2 in the atmosphere would be equivalent only to perhaps a few percent in the ocean. http://www.specialedprep.net/MSAT%20...E/cycleCO1.htm It would not be the first study that attempts to debunk the obvious. Moreover, the oceans and the Earth have survived a multitude of the present carbon dioxide level without much problems: http://calspace.ucsd.edu/virtualmuse...C_Fig4_2_1.jpg |
| Nov22-04, 01:18 AM | #11 |
Incidentely here is a study to the effects of carbon dioxide fertilisation.
Talking about growth, that's also tree ring growth and carbon dioxide fertilisation actually started in 1850 when the carbon dioxide level started to rise from a steady 280 ppm to abut 370 ppm nowadays. Tree rings must have reacted to that. And tree ring growth is the mainstay for climate research in the past millenium. See Jan Esper for instance. See that he also opposed to the hockeystick. I wonder why this publication (Science, Vol 295, Issue 5563, 2250-2253 , 22 March 2002) never got the attention. Now I read all kind of corrections but perhaps I'm overlooking a correction for carbon dioxide fertilization. Obviously the tree rings should have reacted on that. I wonder if any of the tree ring wizards (Storch?) corrected for carbon dioxide fertilisation. If none of the authors did (but I don't have a clue at the moment) then the 1850 - present increase in tree ring thickness should be partly caused by direct increase of growth due to carbon dioxide fertilisation. A possible correction for that would drop the assumed temperature rise in that period, cooling down the apparant warming. |
| Nov22-04, 02:14 AM | #12 |
Lets talk oceans again.
Another thought about anthropogenic moving around of carbon, because that is what we do. Pebrew, you were worried about the effect of carbon dioxide to the oceans. But humanity has already commited a serious crime against the oceans, by fishing these empty. Consequently removing a lot of biomass and carbon out of the oceans, ultimately turning them into lifeless deserts. What we see now is the return of carbon to the oceans. Not in the form of biomass yet. But all kind of micro-organisms (algae) could thrive on that, being on the bottom of the food chain. And this could be the start of restoring biomass to the oceans. Of course there is a lot of unbalance right now and that will be hurting the micro-organisms like foraminifera. Mass extinctions of them are not uncommon. The last disastreous one was in the mid-pleistocene some 1,000,000 to 700,000 years ago (- giving a substantial basis for my hypothesis as important piece of the puzzle). But as a whole the oceans would need the carbon dioxide to restore normal life. |
| Dec1-04, 02:27 AM | #13 |
indeed, CO2 will help repopulate the oceans and that is important. but if the oceans' pH changes appreciably in the next few decades, that is only going to be a bigger problem, exacerbating the lifelessness of the oceans. and that might be okay on the timescale of hundreds of thousands of years; no the earth will not implode. but it would be a problem for modern humans and their civilizations.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Global warming- Yes or no?
| Global Warming | Earth | 35 | ||
| global warming | Earth | 1 | ||
| global warming | Introductory Physics Homework | 4 | ||
| Global Warming | Earth | 10 | ||
