Interferometer Capabilities for Detecting Wavelength Differences
  • Context: Graduate
  • Thread starter Thread starter TheAntiRelative
    Interferometer
The discussion centers on the capabilities of a Michelson interferometer, specifically the 1887 model, in detecting wavelength differences between two light beams. It is established that while the interferometer can produce visual interference rings with beams of slightly different wavelengths (e.g., 600nm and 600.06nm), these rings will be less defined due to the oscillation caused by the wavelength difference. The participant posits that the interference pattern may appear as averages of sets of waves rather than distinct single waves, leading to a constantly shifting phase relationship that may not be visually detectable by the human eye.
  • Understanding of Michelson interferometer principles
  • Knowledge of light wavelength and interference patterns
  • Familiarity with phase shifts in wave mechanics
  • Basic concepts of optical calibration techniques
  • Research the mathematical principles of interference patterns in optics
  • Learn about advanced interferometry techniques for wavelength measurement
  • Study the effects of wavelength differences on interference fringes
  • Explore calibration methods for interferometers in experimental setups
Physicists, optical engineers, and researchers interested in wave mechanics and interferometry applications in experimental physics.
TheAntiRelative
This is actually a copy of a thread I put in the Relativity forum because I figured interferometry was something of importance in that area but because the question is somewhat strange and might require direct experience I thought I'd copy it in here as well to see if someone might know something.
Thanks
Please correct me if/where I'm wrong in my understanding of the following (laymans terms) explanation and question:
A michelson interferometer like used in 1887 works off a basic principle of having the same beam of light arrive at the same place slightly behind/ahead of itself. We are able to see interference (rings) by making the light's direction strike a flat surface at differing angles thereby causing both addative and subtractive interaction to be seen across that surface.
The assumption for this system to work is that both beams of light are of exactly the same wavelength but because of the differing initial arrival times there is a constant and consistent phase (arrival) difference. The peaks are constantly the same distance apart.
If used in a certain way, an interferometer (of a little different design than michelson 1887) can also be used to determine the wavelength of an unknown beam of light when interfering with a known lightsource. However, michelson's interferometer was not used/designed to detect this.
The Queston:
If a michelson interferometer of the design and methodology of use of the 1887 model received 2 beams of slightly unlike wavelengths, what would be seen? (For example, a beam of 600nm and a beam of 600.06nm)
From what I understand, you could still establish visual interference rings but not as well defined because of the oscillation action that would be caused. Is this true?
Without the equipment I could mentally see reasons why this could be true and reasons why this could be false.
True because I know interference rings are seen when using an interferometer to determine an unknown wavelength diferent than the reference beam, But I don't know if they stand still.
False because oscillation would seem to cause blurring...
I lean toward believing that the rings become averages of sets of waves instead of representative of single waves.
If true...
At this point since the two beams are not the same, there seems to no longer be any such thing a a phase shift since the lineup of peaks and troughs is constantly moving.
Would it be oscillating slowly enough to be able to visually set up a temporary lineup of peaks or does it oscillate too fast for the human eye? (I would guess that even as small of a difference as I mentioned, the ocillation rate would be far above the 30somthingish times per second that a human eye can detect.)
Now if the instrument was calibrated to show rings with two different wavelengths, is it true that you could still detect a phase shift but only on an order of magnitude smaller in proportion to the number of waves averaged to create each fringe?
Thanks in advance for your answers :)
Science news on Phys.org
  • · Replies 33 ·
