Relativistic mass of falling body
The discussion revolves around the concept of relativistic mass of a body falling toward a gravitating body, particularly in the context of general relativity (GR) and special relativity (SR). Participants explore the implications of velocity measurements, the definition of mass in different frames of reference, and the effects of gravitational fields on these concepts.
  • One participant questions whether the relativistic mass of a falling body near a gravitating body is equal to its rest mass at infinity.
  • Another participant notes that "relativistic mass" is an outdated concept in modern GR literature, suggesting that it is safer to express equations of motion in terms of energy and proper time.
  • It is mentioned that an observer on the falling mass would not perceive any unusual effects, while an observer at infinity would see the mass gaining velocity, which could be calculated using the SR formula for relativistic mass.
  • Some participants argue that the velocity of the falling body should be measured by a co-located observer, as defining relative velocity in GR for non-colocated observers is problematic.
  • One participant emphasizes that the definition of velocity in GR is ambiguous unless the particles are at the same point in spacetime, due to the curvature of spacetime affecting parallel transport.
  • Another participant discusses the implications of a falling mass impacting a surface and how the kinetic energy is converted into heat, raising questions about the mass of the gravitating body after the impact.
  • One participant challenges the view that relative velocities cannot be defined in GR, citing GPS satellites as evidence of accurate relative time rates calculated from different positions in space.
  • Concerns are raised about the validity of assessing the velocity of the falling mass based on a stationary observer's perspective, suggesting that this leads to circular logic.
Participants express multiple competing views regarding the definition and relevance of relativistic mass, the measurement of velocity in GR, and the implications of these concepts on the understanding of mass and energy in gravitational fields. The discussion remains unresolved with no consensus reached.
Participants highlight limitations in defining relative velocities in GR, the dependence on observer location, and the challenges in assessing energy conversion during the falling process. These factors contribute to the complexity of the discussion without providing clear resolutions.
zonde
Let's say that body with rest mass m0 is falling toward gravitating body from infinity.
Near gravitating body it falls with speed [tex]v=\sqrt{\frac{2MG}{r}}[/tex]
Is it right that relativistic mass of body falling at speed v near gravitating body is equal to the rest mass of the same body at infinite distance from gravitating body?
Most modern GR books don't even talk about "relatiivstic mass" anymore. it's mostly an outdated SR concept that didn't make it to "the big time", though you'll find the occasional vocal enthusiast.
That said, you might find a few very old books (Tollman's Relativity, Thermodynamics, and Cosmology is the only one that comes to mind) that might find a way to use "relativistic mass" in a way that's compatible with GR.
However, it seems safest to write that any correct esxpression for the equations of motion for a radial infall would be equivalent to finding two functions
r(tau), t(tau)
such that
(dr/dtau)^2 + (1-2M/r) = constant = "energy at infinity" = E
(dt/dtau) = E / (1-2M/r)
(I've omitted the radial terms, see for example http://www.fourmilab.ch/gravitation/orbits/ for the full formula)
I would suspect that if you try simple-minded substitutions for the "relativistic mass" using SR formulae that ignore the metric coefficients that you'd get an incorrect answer, but I haven't verified this.
An observer sitting on your falling mass would not see anything unusual. He does not feel any acceleration and might assume he is floating free in open space. The actual rest mass M upon which he sits has not changed.
An observer at somewhere approximating infinity would see the falling mass as having acquired a velocity (assuming he could actually see that far from approximately infinity). Any mass that acquires a velocity is subject to the normal Special Relativity formula M/(1-v^2/c^2)^1/2. In your example, this is a relativistic mass that could be tested in a laboratory near the surface of the planet before it got to the Schwarzschild Radius (for example, the falling mass could impact an object in the laboratory and the relativistic mass would be applicable to this collision per the above formula).
The velocity given by [tex]\sqrt{\frac{2MG}{r}}[/tex] is not measured or defined via an observer at infinity.
This velocity is the velocity measured by a "stationary" observer at the same location as the falling object.
I suppose the same co-located observer could then use the SR relativistic mass formula to compute the relativistic mass , because you can treat space-time as being locally flat.
The purist view (see http://math.ucr.edu/home/baez/einstein/node2.html) is that there isn't any good definition for relative velocity in GR for non-colocated observers, thus there isn't any good definition of the velocity of the falling object relative to the observer at infinity.
baez said:
In general relativity, we cannot even talk about relative velocities, except for two particles at the same point of spacetime -- that is, at the same place at the same instant. The reason is that in general relativity, we take very seriously the notion that a vector is a little arrow sitting at a particular point in spacetime. To compare vectors at different points of spacetime, we must carry one over to the other. The process of carrying a vector along a path without turning or stretching it is called `parallel transport'. When spacetime is curved, the result of parallel transport from one point to another depends on the path taken! In fact, this is the very definition of what it means for spacetime to be curved. Thus it is ambiguous to ask whether two particles have the same velocity vector unless they are at the same point of spacetime. In general relativity, we cannot even talk about relative velocities, except for two particles at the same point of spacetime -- that is, at the same place at the same instant. The reason is that in general relativity, we take very seriously the notion that a vector is a little arrow sitting at a particular point in spacetime. To compare vectors at different points of spacetime, we must carry one over to the other. The process of carrying a vector along a path without turning or stretching it is called `parallel transport'. When spacetime is curved, the result of parallel transport from one point to another depends on the path taken! In fact, this is the very definition of what it means for spacetime to be curved. Thus it is ambiguous to ask whether two particles have the same velocity vector unless they are at the same point of spacetime.
Then let's say that distant observer sees such a sequence of events:
Test mass falls toward large gravitating object and hits the surface.
Kinetic energy of test mass is converted into heat and then radiated away.
Now summary mass of gravitating object has increased by rest mass of falling object that it had at the moment when it hit the surface. But this rest mass should be less than initial rest mass when test body started to fall as we have to take into account energy that was radiated away and does not contribute to summary mass any more.
Is the problem now well defined? If yes are my conclusions correct?
I disagree with baez. Current GPS satelites calculate the relative time rates from their position in space relative to the time rates on the surface of the Earth and have been experimentally shown to be accurate. To say that at any point in space you cannot possibly know what is happening at any other point is a statement of the invalidity of General Relativity. If the local stationary observer at the lesser radius is the only person who can know the true velocity of the falling mass, then how does this local observer know that the mass started out at zero velocity when it was at approximately infinity. The problem becomes insolvable.
The mass starts falling from a position in space where he is next to the observer. This is the reference point from which his potential energy is converted into the kinetic energy which converts into his relativistic mass. This is the only valid reference point from which the assessment of his final kinetic energy can be made. How could anyone possibly know that the local observer at the lesser radius was stationary? You could only calculate the potential energy of a stationary observer at the lesser radius, but this would be done by converting his position back to the position approximating infinity. But that's circular logic.
Have to say that I feel the same way. If we can't use GR to make statements about physical situation that spans area with different gravitational potentials then how is it theory about gravity?
  • · Replies 17 ·
  • · Replies 45 ·
  • · Replies 23 ·
  • · Replies 55 ·
9K
  • · Replies 125 ·
