How Does Baking Soda Absorb Odors?
  • Thread starter Thread starter jmnew51
    Absorbtion
Baking soda, scientifically known as sodium bicarbonate, effectively absorbs odors due to its weakly alkaline nature, allowing it to neutralize acidic odors. It can be applied in powder form directly onto carpets or used in a solution with water, although its efficacy may be reduced if the source of the odor is not addressed. While baking soda can help with general odor absorption, it may not be effective against strong odors, such as those caused by ammonia. For optimal results, it is recommended to use it in conjunction with proper cleaning methods.
  • Understanding of basic chemistry principles, specifically acid-base reactions.
  • Familiarity with household cleaning techniques.
  • Knowledge of carpet care and maintenance.
  • Experience with odor neutralization methods.
  • Research the chemical properties of sodium bicarbonate and its applications in odor neutralization.
  • Learn about effective carpet cleaning techniques, including the use of cleaning machines.
  • Investigate the use of activated charcoal for odor absorption and compare it with baking soda.
  • Explore other household items that can neutralize odors, such as vinegar and essential oils.
This discussion is beneficial for homeowners, cleaning professionals, and anyone interested in effective odor management solutions for carpets and other household areas.
jmnew51
I do not understand why baking soda is a good absorber of odors. Is it like activated charcoal or something? The reason I ask is because I have patch of odor in my carpet and someone suggested sprinkling baking soda on it. I just do not see this working. Also I have a carpet cleaning machine so could I put some baking soda into the solution and use it that way? Or does it have to be in powder form?
Thank you
Jim
Chemistry news on Phys.org
Baking soda is weakly alkaline, hence it can react with odors with acidic origins and neutralize them. You could put in water to use.
Well I used a lot of ammonia on the carpet so if that did not work I guess the baking soda won't either. How does it absorb odors from your fridge by just putting an open box in there?
Jim
  • · Replies 18 ·
  • · Replies 22 ·
12K
10K
28K
  • · Replies 27 ·
27K
