Steam and ice interact, find final temperature
The discussion focuses on calculating the final temperature when 5.0 g of steam at 100°C interacts with 20 g of ice at 0°C, resulting in 25 g of water. The key equation used is delta Q = mC(delta T), where m is the mass of water and C is the specific heat of water. Participants emphasize the importance of calculating the thermal energy lost by the steam during condensation and the thermal energy gained by the ice during melting, utilizing the latent heats of vaporization and fusion. A critical step is verifying whether all the ice can melt with the available energy from the steam.
  • Understanding of the specific heat capacity of water
  • Knowledge of latent heat of vaporization and fusion
  • Familiarity with thermal energy calculations
  • Basic principles of thermodynamics
  • Calculate the latent heat of vaporization for water
  • Learn about the latent heat of fusion for ice
  • Study the principles of thermal equilibrium
  • Explore the concept of specific heat in different states of matter
Students studying thermodynamics, physics educators, and anyone interested in heat transfer calculations involving phase changes of water.
mindarson
Problem:
If 5.0 g of steam at 100 deg C interacts with 20 g of ice at 0 deg C, what is the final temperature of the resulting 25 g of water?
My thinking on the solution:
I figure I can use the equation
to calculate the final temperature, where m = 25 g and C is specific heat of water.
I can find delta Q by calculating how much thermal energy the steam loses in condensing and subtract how much thermal energy the ice gains in melting, using the latent heats of vaporization and fusion respectively.
Am I on the right track here?
You're thinking along the right lines. In general you'll want to verify whether or not all of the ice can melt with the energy available, or if you'll end up with a mixture of some ice and some water. So compare the energy you'd get from condensing the steam and taking the resulting water to zero C with the energy required to melt all of the ice. If there's more than enough energy left over, then proceed as you've indicated.
