Understanding UTF-16 Encoding for Multilingual Character Sets
  • Thread starter Thread starter kandelabr
This discussion clarifies the encoding of characters in UTF-16, emphasizing that it is a variable-length encoding capable of using either 2 or 4 bytes per character. The misconception that all characters in UTF-16 are fixed at 2 bytes is addressed, with a distinction made between UTF-16 and UCS-2, the latter being a fixed-length encoding. Concerns regarding the handling of 4-byte characters in Windows API (WINAPI) using WCHAR, which is 2 bytes long, are discussed, highlighting that characters requiring more than one WCHAR will be represented as a sequence of WCHARs in the program.
  • Understanding of UTF-16 and its variable-length encoding
  • Familiarity with WCHAR data type in C programming
  • Knowledge of Unicode character sets and their representations
  • Basic concepts of Windows API and string handling
  • Research the differences between UTF-16 and UCS-2 encoding
  • Learn how to handle multi-byte characters in C using WCHAR
  • Explore Windows API functions that support UTF-16 encoding
  • Investigate character encoding best practices for multilingual applications
Software developers, particularly those working with Windows applications, and anyone involved in internationalization and localization of software products.
kandelabr
Hello all,
I hope I understand this correctly:
In UTF-8 all ASCII characters are 8 bits long and other, more sophisticated, 2 to 4 bytes.
Every character in UTF-16 is 2 bytes long. So, how does one encode a character that is, say, 4 bytes long in UTF-16?
I'm asking because I'm a bit worried - in WINAPI (plain C), every unicode function is based on WCHAR that is 2 bytes long. Also all (my) string parsing and handling is based on "fact" that every character takes up 2 bytes. What happens if I enter a 4-byte character? All my strings go to hell?
Thanks.
Technology news on Phys.org
Yes.
No; actually, according to Wikipedia, UTF-16 is also a variable-length encoding that can use either 2 or 4 bytes per character. You may be thinking of UCS-2, which is a fixed-length encoding using 2 bytes per character; in that encoding it's impossible to represent any character with a Unicode code point greater than 65535.
I'm not familiar with Windows programming, but it might be that WCHAR is really just a 16-bit unit of data that doesn't necessarily have to map one-to-one to a single character. In that case, what you actually pass to the function is the UTF-16 encoded representation of the string you want to process (or perhaps it uses a different representation). If your string includes characters that are represented by more than one 16-byte unit in UTF-16, then those characters will correspond to a sequence of more than one WCHAR in the WCHAR[] in your program.
thanks for the reply
by accident i found this in my offline help:
Wide characters are multilingual character codes that are always 16 bits wide. The type for character constants is char; for wide characters, the type is wchar_t. Since wide characters are always a fixed size, using wide characters simplifies programming with international character sets.
also, if you look at the windows character map - advanced view, you cannot enter more than 4 characters into edit box "Go to unicode".
to me it looks like windows has support for utf-16, but a bit abridged.
