Magnetic force on a current carrying wire
The formula for calculating the force on a current-carrying wire is given by F = BIL, where F represents the force, B is the magnetic field strength, and L is the length of the wire. This formula assumes a uniform magnetic field along the wire's length, which may not hold true in practical scenarios. The magnetic field B must be evaluated at the wire's location, and variations in distance from the magnet will affect the field strength experienced by the wire. Demonstrations typically utilize bar magnets or horseshoe magnets to create an approximately uniform magnetic field in the relevant region.
  • Understanding of electromagnetic theory
  • Familiarity with the Lorentz force law
  • Knowledge of magnetic field strength measurement
  • Basic principles of magnetism and magnetic fields
  • Study the Lorentz force law in detail
  • Learn about magnetic field strength calculations at varying distances
  • Explore practical demonstrations using bar magnets and horseshoe magnets
  • Investigate the effects of non-uniform magnetic fields on current-carrying conductors
Physics students, electrical engineers, and educators seeking to deepen their understanding of magnetic forces on current-carrying wires.
pantheid
Hi, I am slightly confused by the formula for finding the force on a current carrying wire. It is given as F=BIL where F is force, B is the strength of the magnetic field and L is the length of the wire being acted upon. What I don't understand is why this formula doesn't factor in the distance between the magnet and the wire itself.
The magnetic field B is taken to be the field present at the wire itself. Any position dependence of B must be known in order to know the field at the wire. So, yes a far aways magnet will have less force on the wire, but it will also present less magnetic field to the wire. You would not want to use the value of B near the magnet in the calculation of force on a wire a long distance away.
Note that this formula is a simplification that assumes the magnetic field is uniform over the entire length of the wire, which is not likely to be true for a real magnet and a wire of any appreciable length.
The usual arrangement for demonstrating this involves using a pair of bar magnets (using the gap between a N and opposing S pole), or else a horseshoe magnet, and this arrangement makes the field in that region approximately uniform.
  • · Replies 22 ·
  • Sticky
  • · Replies 0 ·
  • · Replies 27 ·
