Buoyancy in Free-Falling Elevator: Explained
  • Context: Undergrad
  • Thread starter Thread starter daveed
    Balloon Elevator
The discussion centers on the behavior of a balloon in a free-falling elevator, specifically addressing buoyancy forces. When the elevator descends in free fall, buoyancy forces become negligible as the entire system accelerates downward, causing air pressure to equalize throughout the elevator. Prior to free fall, gravity creates a pressure differential, with higher pressure at the bottom and lower pressure at the top. If the balloon is released during free fall, it will initially move upward slightly due to air movement, but ultimately, it will remain in free fall alongside the girl and the air inside the elevator.
  • Understanding of buoyancy and pressure differentials
  • Basic knowledge of gravitational effects on fluids
  • Familiarity with concepts of free fall and acceleration
  • Knowledge of air pressure behavior in enclosed spaces
  • Research the principles of buoyancy in varying gravitational conditions
  • Study the effects of acceleration on fluid dynamics
  • Explore the physics of free fall and its implications on objects within a system
  • Investigate real-world applications of buoyancy in moving vehicles
Students of physics, educators explaining buoyancy concepts, and anyone interested in the dynamics of objects in free fall.
daveed
so you have a girl in the elevator with a balloon. the elevator begins to descend in free-fall, and the girl releases the balloon in surprise. my book says that the balloon will stay at the same level relative to the girl as before, which brings me to my question: do buoyancy forces not work when the whole system is in acceleration, then?
could someone please explain this to me?
Balloons float from a high pressure area to a lower pressure area.
When the elevator goes down the air moves to the top making that the high pressure area.
You get the same effect in a car. The balloon will move forward when the car accelerates
In a free fall, there are no buoyancy forces. Air pressure would equalize through out the elevator. Before the freefall, gravity's pull on the air resulted in a slight pressure variance, higher at the bottom, lower at the top. The net pressure differential at the top and bottom of the elevator would equal the weight of the air inside the elevator (about 2 lbs per cubic yard).
If the balloon were released at the moment of free fall, there would be some upwards movment of air as the pressure equalized, so the balloon would move upwards a bit.
If the girl's reaction time to the free fall delayed the relase of the balloon until after the air pressure equalized, then the balloon would remain in free fall, just like the girl and the air inside the elevator.
  • · Replies 22 ·
  • · Replies 23 ·
