Is Work Required to Push Electrons from Positive to Negative Terminal?
  • Thread starter Thread starter Peter G.
    Electricity Work
The discussion clarifies that work is required to push electrons from the positive terminal to the negative terminal in a battery due to the conventional current flow. Peter G. highlights that the positive terminal has a higher potential, necessitating energy input to move electrons against their natural tendency to flow from negative to positive. The chemical reactions within the battery facilitate this movement, releasing energy as electrons return through the circuit. Additionally, the electromotive force (e.m.f) represents the work done per unit charge, equating to the potential difference across the battery.
  • Understanding of conventional current flow and electron movement
  • Basic knowledge of battery chemistry and electrochemistry
  • Familiarity with the concept of electromotive force (e.m.f)
  • Knowledge of potential difference and its significance in electrical circuits
  • Study the principles of electrochemistry in battery operation
  • Learn about the relationship between e.m.f and internal resistance in circuits
  • Explore the concept of potential difference and its calculation in electrical systems
  • Investigate the effects of chemical reactions on electron flow in various types of batteries
Students of physics, electrical engineers, and anyone interested in understanding the principles of battery operation and electron flow in circuits.
Peter G.
Hi,
My book says the electrons must be pushed from the positive to the negative terminal, which means work must be done on the electrons.
I find it a bit confusing. Is the book saying that because we are using the conventional current? Meaning that the positive end of the battery has a high potential and the left end a lower potential hence charge must flow from positive to negative. Then in that case, work would have to be done on the charges (electrons) to make them move against the forces of attraction, since, normally, electrons would move the other way?
Thanks,
Peter G.
In a battery for example the chemical reaction inside moves electrons from + to -. That requires energy. That energy is then released again as the electrons move back through the circuit.
Ok and just one more thing: The e.m.f, that is, the work done per unit charge to move it around the circuit is actually the potential difference across the battery (therefore E.m.f - Ir)?
  • · Replies 44 ·
  • · Replies 22 ·
