Advanced mechanics - x(t) from v(x)
The problem involves determining the position function x(t) of a particle given its velocity as a function of position, specifically v(x) = bx-n. The context is advanced mechanics, focusing on the relationship between velocity and position over time.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of the chain rule and integration to relate velocity and position. There is uncertainty about the necessity of the force function and the integration constants. Some participants explore the integration of a first-order ordinary differential equation (ODE) and the implications of initial conditions.
The discussion has progressed with participants sharing their attempts at solving the ODE and integrating both sides. Some have identified the need for an integration constant, while others are clarifying how to apply initial conditions to find this constant. There is a collaborative exploration of the problem without a definitive consensus on the final form of x(t).
Participants are working under the assumption that x = x0 at t = 0, which influences their integration and the determination of constants. There is also a focus on ensuring that the integration process aligns with the problem's requirements.
tourjete
A particle of mass m's velocity varies according to bx-n
Find the position as a function of time, setting x = x0 at t=0
v(x) = bx-n
possibly relevant: f(x) = -b2mnx-2n-1
The first part of the question asked me to find the force acting on the particle as a function of x, which I did using the chain rule. I'm a little unclear as to whether I need f(x) to get x(t).
Anyway, here's my attempt at a solution:
dv/dt = (dv/dx)*(dx/dt)
dv/dt = (dv/dx) * v(x)
Both of these quantities are known so I plugged them in and got an expression for dv/dt. I then tried to integrate that expression twice, once to get v(t) and another time to get x(t). However, when I do that I just get the expression times t2/2, which would make x(0) = 0, not x0 as the problem statement gives.
Am I doing this the complete wrong way or am I on the right track and just not understanding calculus?
[tex] v = \frac{d x}{d t} = b x^{-n}[/tex]
This is a 1st order ODE with separable variables. The variables separate as:
[tex] x^{n} \, dx = b \, dt[/tex]
which can be integrated by elementary tabular integrals. The one arbitrary constant is found from the initial condition.
Thanks!
I solved the ODE by integrating both sides and got xn+1/(n+1) = bt. I don't see where the constant comes into play here.
Finish the expression for the integration of your ode. What must one add to every indefinite integral of df/dx?
so I have:
xn+1/(n+1) = bt + C
then I plug in the initial condition x=x0 at t = 0
C = x0n+1/(n+1)
I just need to solve this for x now, correct?
yes.
30K
