Solving Radiator Problem - Help Needed | Jefferson123
  • Thread starter Thread starter jefferson123
    Radiator
The discussion focuses on calculating heat rejection for a car radiator using the equation Heat exchange = u x a x deltaT. The primary challenge is determining the heat transfer coefficient (u) for radiators made from aluminum with flat profile tubes and wave fins. Participants emphasize the complexity of the problem due to turbulent flow conditions and suggest using educated guesses for the heat transfer coefficient and surface area to estimate heat transfer rates. The discussion concludes that there is no definitive formula for turbulent flow scenarios, making precise calculations challenging.
  • Understanding of heat transfer principles, specifically Newton's law of cooling.
  • Knowledge of heat transfer coefficients in fluid dynamics.
  • Familiarity with the properties of aluminum, including its heat entropy.
  • Basic concepts of turbulent flow and its impact on heat exchange.
  • Research methods for estimating heat transfer coefficients in turbulent flow scenarios.
  • Learn about the thermal properties of aluminum and their implications for heat exchange.
  • Explore computational fluid dynamics (CFD) tools for modeling radiator performance.
  • Investigate experimental techniques for measuring heat transfer rates in automotive applications.
Engineers, automotive designers, and thermal management specialists seeking to optimize radiator performance and understand heat transfer dynamics in automotive applications.
jefferson123
Hi guys can anyone help
I have a problem trying to find an equation to work out the heat rejection for a car radiator I have
But I cannot find u ?
The radiators have flat profile tubes and wave fin they are made from aluminium, the formulae would have to take this into consideration and work at various mass flows through both the airside. And waterside these would be affected by vehicle speed ie the force of air pushed through the radiator. Can anyone help as I have been looking at this for hours and not getting anywhere.
Please help
Cheers
Jefferson123
Well first you would need to know the heat entropy of aluminum. That is, how many joules of energy is required to raise (or lower) its temperature by 1 degree... You also need to know the total surface area both exposed to the coolant inside, as well as the air outside...
it's been a while since I've done a problem like that so I'd have to pretty much relearn it myself beyond that. Maybe someone else will chime in.
this problem is impossible, i.e. there exists no "formula" that gives heat transfer rate. This goes for any problem with turbulent flow. In a nutshell, water+air+metal combination = game over.
You get a "guess" by guesstimating the area of the fins, guesstimating a heat transfer coefficient and taking the coolant temperature as constant; then do the classic Newton's law of cooling. Errors are probably lower if you take an educated guess, let me just warn you on that...
