Tisthammerw said:
I've seen one guy claim there's no such thing as electrons. Not wanting to disbelieve my physics textbooks, can anyone help me here?
When someone makes claims like this its due to a poor understanding of the physics involved. People like this usually think that they're the only ones in the universe to have considered these questions or that if they can't figure it out then it can't be figured out. It can prove a useful exercise to address these things to some extent so as to solify the concepts in your own mind. But at one point you need to not bother anymore.
Standing wave in a feed line or antenna means that there is a voltage and a charge at one point and not at another even though the two places are connected by a conductor. If there were electrons, this would imply that one spot in a conductor had many electrons clustered and snother spot a few inches away had none. Even though no resistance inhibits the flow of electrons from the point of maximum charge to the point of no charge. This is contrary to electron behavior according to electron theory.
It's pretty interesting how he thinks this contradicts electron theory whereas one uses the notion of charge to make these predictions. Notice that his argument does not address whether
electrons exist, but whether
charge itself exists and the properties of charge etc.
A standing wave on a conductor for which the energy flow is parallel tothe x-axis means that the fields are of the form
E = E
0(y,z)cos[itex]\omega t[/itex] sin [itex]\beta x[/itex]
j
The field is not really inside the wire, its outside for the most part. There is a surface charge density which is
not static and charge is shuffled back and forth resulting in a finite surface current. Your friend has the wrong idea of what a standing wave is. He probably thinks that a standing wave is time independent when it really isn't.
What (according to electron theory) is the difference between those atoms in the outer layer and those in the inner part of a conductor?
There is nothing different about the atoms. There is everything different about the
location of the atoms. The atoms at the outer layers are subjected to the electric field which impinges on the conductor form an EM wave that impinges on it. The deeper the wave penetrates into the conductor the more the wave is atenuated due to the charges rearranging themselves due to the electric field. Very hard to explain in words. That's why we have equations.
Electron theory says that the positive pole of a battery has a deficiency of electrons and the negative pole has an excess. If that were true, connecting the positive pole of one battery to the negative pole of another battery would cause current to flow, but in the real world it doesn't.
Its easier to answer this in terms of capacitors since batteries require an understanding of chemistry and this is physics. Therefore take as an example two identical capacitors with identical charge on them; Let the negative pole of one cap be connected to the positive pole of another cap. Current
will flow in order to balance out the charges between the plates in order to reduce the net charge to zero. The charges will then rearrange themselves on the conductor and the surface charge density of the conductors will not be zero, although the total charge
will be equal to zero.
Now, explain to me in terms of electron theory why lead-acid batteries have internal resistance and NiCad batteries don't?
Invalid claim. NiCad batteries have
extremely low internal resistance,
not zero internal resistance.
The most up-to-date and recent findings on electron research find that there is no discernable estension, no shape, no size. They are point sources, and the theory says if they are point sources they would have infinite energy, but in the real world they don't.
Invalid assumption. We don't know that the size of an electron is zero. We just can't measure the size its so small. Classically the electron does have a radius. Quantum mechanics is a different theory made to fill in the inadequacies of classical theory so I'm sure quantum field theory has more to say on this point.
Re - infinite energy of point charge - I've never liked that idea. Consider where this notion comes from. The energy in an electric field is defined as the potential energy of the charge configuration which is equal to the work done to construct the charge configuration from charges which start out at infinity. But a point charge is not something which is assembled. Consider the derivation of the relation for energy and energy density in such a field. One starts out with the discrete case and takes a limit. The discrete case starts off with a single charge and the energy of the configuration is taken to be zero -
by definition. One then brings charges in from infinity to
finite distances from each other charge already there. One then obtains a relationship for a number of charges etc. One then assumes that the value of each charge goes to zero while the number of each charge goes to infinity - an unreal assumption with finite point charges - i.e. electrons.
Once again, anticrank says "all batteries have internal resistance". Bull. No batteries have internal current.
Clearly an unfounded claim. He seems to have the idea that if he writes/says something then it is automatically true. I think not. Batteries which are, say, lighting a bulb
do have an internal current in them.
Alkali electrolyte batteries can be modeled as if they had a resistor in parallel, meaning that under load the voltage remains the same, but current will decrease.
This statement is quite unclear. What is he talking about? If I model the internal resistance of a battery with a parallel resistor (which is how its done actually) then current flows when a load is attached. The internal resistance remains unchanged but the external resistance will depend on what is attached, i.e. will depend on what the battery is powering. The voltage of the ideal battery is constant but the voltage of the real battery will decrease with increase in current.
Tell anticrank to explain how his famous internal resistance changes with the load.
Tell the crank that he's wrong.
I bet he'd love the book
There Are No Electrons by Kenn Amdahl
Pete
