Position of Ascending and Descending Nodes
  • Context: Graduate
  • Thread starter Thread starter TheHarvesteR
    Nodes Position
The discussion focuses on determining the position of ascending and descending nodes in orbital mechanics, specifically how to calculate the altitude at these nodes relative to a central body. Participants explore methods for visualizing these points in an orbital visualization system.
  • One participant seeks to find the altitude at the ascending and descending nodes, having already determined the longitude of the ascending node and a unit vector pointing to it.
  • Another participant suggests using the cross product of the geocentric Z axis and the angular momentum vector to find a vector pointing towards the ascending node.
  • It is proposed that the true anomaly at the ascending node can be found by subtracting the argument of perigee from 360 degrees, which could simplify the calculation of the node's position.
  • A formula for the radius at the ascending node is provided, involving the angular momentum vector and the eccentricity vector.
  • A later reply confirms that the suggested method for finding the true anomaly worked effectively for determining the positions of the nodes.
Participants generally agree on the methods proposed for calculating the true anomaly and the position of the nodes, with one participant confirming the effectiveness of the approach. However, the discussion does not resolve all potential methods or nuances related to the calculations.
Participants discuss specific calculations and methods without resolving all assumptions or dependencies on definitions, such as the exact nature of the angular momentum vector and its calculation at different points in the orbit.
TheHarvesteR
Hi again.
I'm trying to determine the position of an orbit's ascending and descending nodes here. I already have the Longitude of the ascending node, and a unit vector that points to it, so what I now need is a way to find out the actual distance of the node from the central body.
More specifically, I'm trying to find some way to determine what my "altitude" would be at the ascending and descending nodes. Or, the point at which the line of nodes intersects the orbit.
So far I haven't had much luck with this one, all I can find are directions for calculating the longitude of the ascendind node, but nothing about it's actual distance from the central body.
The reason I'm trying to find these points is that I'm building an orbital visualization system here, and I'm placing icons over the more important points of the orbit, like periapsis, apoapsis, object position, and ascending and descending nodes. All other points are accounted for, but I'm missing that one bit of information to correctly place AN and DN.
Any help would be greatly appreciated.
Thanks in advance,
Cheers
Astronomy news on Phys.org
How did you find a vector that pointed towards the ascending node?
The normal way is to take the cross product of unit vector k (which lies on the geocentric Z axis) and your angular momentum vector, which means you have the angular momentum vector and can calculate its magnitude.
How did you find a vector that points towards perigee?
The normal way is to create an eccentricity vector that's derived from the LaPlace vector.
You can use the dot product of the eccentricity vector and your line of nodes to find the cosine of true anomaly. The easier way would probably be to subtract your argument of perigee from 360 to actually find your true anomaly at the ascending node. Once you have your true anomaly, you can use the following version of the trajectory equation to find the magnitude of your radius at the ascending node.
[tex]r = \frac{h^2/\mu}{1 + e cos(\nu)}[/tex]
with h being the magnitude of your angular momentum vector
mu being your geocentric gravitational constant
e being the magnitude of your eccentricity vector (or just your eccentricity if you're getting your info from elsets)
And your angular momentum vector is the cross product of the position vector and the velocity vector. Since it remains constant, you can calculate it anywhere in your orbit. It's easiest to calculate at perigee or apogee since the velocity vector is perpendicular to the position vector at those two points. In other words, at perigee and apogee, the magnitude of your angular momentum is just your radius times your velocity (with both measured in either meters & meters/sec or km and km/sec, depending on the units you want your final answer to be in).
This just might work :)
I already have functions set up to get a position given a true anomaly angle, so if I can find the true anomaly of the nodes, I pretty much aready have their positions.
I'll give this a try now. I'll let you know how this goes.
Thanks! (BTW, I'm loving these forums :smile: )
Cheers
Worked perfect! So simple and elegant!
Thanks a million!
Cheers
10K
  • · Replies 45 ·
84K
