How Do You Calculate Final Velocity with Constant Acceleration?
The discussion revolves around calculating the final velocity of a car under constant acceleration, given its initial velocity and distance traveled over a specific time period. Participants are exploring the relationship between velocity, acceleration, and displacement in the context of kinematics.
  • Participants express confusion regarding the relevant equations and the meaning of the variables involved. There is a focus on understanding the definition of acceleration and its implications for velocity over time. Some participants suggest alternative ways to approach the problem without relying solely on the provided equation.
Several participants are actively engaging in clarifying concepts and definitions related to the problem. Guidance has been offered regarding the interpretation of variables and the relationships between them, but there is no explicit consensus on a solution yet.
Participants mention a lack of practice examples in their textbook, which contributes to their confusion. There is also an acknowledgment of the need to understand the correlation between the variables and the specific numbers given in the problem.
albodibran
a car is at a velocity of 20 km/h if the car traveled 120 km in 3 hours at constant accelration. what is the final velocity?
V^2=Vo^2+2ad
I am completely confused. The book does not even list the particular formula above. And not much practice examples are given . I have an issue with understanding these variables. I don't see the correlation between the variables and the particular numbers. and its making a potentially easy problem non understandable.
please help
Welcome to PF albodibran!
V^2=Vo^2+2ad
please help
In the equation you typed above, v is the current velocity (when the object is at distance d from its starting point), v0 is the initial velocity (when the object began accelerating). The variable 'a' is the acceleration (which is constant in this case) and d is the total displacement.
However, you don't need this equation. In fact, you don't even need the distance value you were given. Answer this question: what is the definition of acceleration?
Bearing in mind the definition above, if you have an acceleration value, and a time interval, what can those two things tell you about the velocity over that time interval?
First, welcome to PF!
Let's see if we can help get you straightened out.
If we have constant acceleration,
[itex]V= V_0 + at (1)[/itex]
[itex]V[/itex] is the final velocity, [itex]V_0[/itex] is the initial velocity, [itex]a[/itex] is the acceleration, and [itex]t[/itex] is the time.
Also, we have the displacement,
[itex]d = \frac{1}{2}(V + V_0) t (2)[/itex]
[itex]d[/itex] here, as said, is the distance traveled, also known as displacement.
If we rearrange (1) to solve for t, we get
[itex]t = \frac{V-V_0}{a} (3)[/itex]
Now from here, just substitute (3) into (2) for t. You then have:
[itex]d = \frac{1}{2}(V + V_0) (\frac{V-V_0}{a})[/itex]
When you work out your multiplication (I hope you're verifying what I'm doing here, it'll help) and rearrange things,
[itex]V^2 = V_0^2 + 2ad[/itex]
Does that help you to see where they are coming from? If not, let us know and we'll see what we can do for you.
I figured that out thank you I will post a issue I have with part of another problem
  • · Replies 20 ·
