New Reply
Piece wires : Temperature
Share Thread Thread Tools
Sep29-11, 09:45 PM   #1
hye... i new user (forumer)... help me....
1) i have 3- 4 piece wire (copper/ iron)... i dont know AWG for piece wire... no label... the length of wire is 1 foot... how to know / measure / calculate the maximum voltage, maximum current, maximum temperature, thickness, type of metal for piece wire.
2) temperature relation / propotional - voltage
- current
-conductivity
-resistivity
*formula / definition
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> NASA: Austin, calling Austin. 3-D pizzas to go
>> Research suggests modular design competence can benefit new product development
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
Sep29-11, 11:29 PM   #2
Recognitions:
Gold Membership Gold Member
current capability of a wire is primarily proportional to its diameter (thickness) ( and somewhat to the type of wire... copper, aluminium etc) you need to find out what you wire is what its made of, what its size is AWG etc.
its resistance is also dependant on what its is ... copper etc and thickness
known cables will have data sheets that will state that info along with its resistance in Ohms / metre(foot) km(mile) etc
we cant help you without that information
cheers
Dave
Sep29-11, 11:52 PM   #3
Recognitions:
If you have a pair of calipers (or better yet, micrometers), measure the diameter of a STRIPPED portion, and then read it off the chart (this will be a little problematic if the wire is stranded, but not impossibly so):
http://en.wikipedia.org/wiki/American_wire_gauge
Note that the information is rule of thumb ONLY. Temperature rating, maximum voltage, and resistance will depend on the insulation used (if any) and the history of the piece (i.e. if it's severely kinked or cut-up in certain areas, the resistance will increase).
For something where this really matters, get some new pieces of wire. They're pennies per feet.
EDIT: and pursuant to my point about the 'history' of the piece, this will affect its current-carrying capability.
Sep30-11, 03:30 AM   #4
Recognitions:
One way to measure the diameter of a wire is to wind the wire around a cylinder (like an AA battery) so that the turns are right up close to each other.
Then measure one inch or one centimeter along the coil and count how many turns of wire are in that distance. From this, it is easy to work out the diameter of the wire.
The most common wire is probably copper. This has an orange-red colour and bends easy.
Iron wire is attracted to a magnet and it is harder to bend than copper.
Aluminum wire is silvery-white when cut but it turns to s smoky white as it oxodises.
Another type you may come across is Nichrome wire. This is very springy and will not wind into a coil easily. It has a very high resistivity and so quite a short piece of this wire has a lot more resistance than a similar piece of copper wire.
Here is a list of resistivities which will give you a comparison between different materials as conductors.
http://en.wikipedia.org/wiki/Resistivity
Also see the wire table given above in a previous post.
Oct2-11, 11:41 PM   #5
Quote by davenn View Post
cheers
Dave
how do know the size of AWG? wire made (material) ???
Oct3-11, 01:43 AM   #7
Quote by MATLABdude View Post
current-carrying capability means ???
Oct3-11, 02:42 AM   #8
Quote by puteh30 View Post
wire above? iron or aluminum?
Oct3-11, 08:20 AM   #9
Recognitions:
Homework Helper Homework Help
magnet?
Oct3-11, 08:23 AM   #10
Recognitions:
amps
Oct3-11, 08:25 AM   #11
Recognitions:
yellow=copper
black = ??????
Oct3-11, 09:15 AM   #12
Recognitions:
Quote by NascentOxygen View Post
yellow=copper
black = ??????
= charred?
Oct3-11, 07:26 PM   #13
1) i have 3- 4 piece wire (i dont no type of metal piece wire)... i dont know AWG for piece wire... no label... the length of wire is 1 foot... how to know / measure / calculate the maximum voltage, maximum current, maximum temperature, thickness...
2) temperature relation / propotional with
- voltage
- current
-conductivity
-resistivity
*pls give formula / definition....
http://img192.imageshack.us/img192/7...cn5043x.th.jpg
http://img4.imageshack.us/img4/2913/dscn5051f.th.jpg
Oct4-11, 02:41 AM   #14
help me....
Oct4-11, 11:42 AM   #15
Mentor
- voltage
- current
-conductivity
-resistivity
Welcome to the PF. What is the context of your question? You are trying to figure out the maximum ratings for these wires, given only 1 foot samples? What other information do you have? What is the application for the wire?
You use standard wire tables and/or the manufacturer's datasheet to figure those things out.
http://www.powerstream.com/Wire_Size.htm
Oct5-11, 08:07 PM   #16
Quote by berkeman View Post
What other information need i have? What is the application for the wire? pls help me
Oct5-11, 10:42 PM   #17
Recognitions:
No one knows. We need you to tell us about it.
Did you salvage it from a space vehicle?
New Reply
Tags
conductivity, copper, current, iron voltage, resistivity, voltage, wire, wires
Thread Tools
Similar Threads for: Piece wires : Temperature
Thread Forum Replies
Ice piece Introductory Physics Homework 18
Advantages/disadvantages of twisted wires VS wires bundled next to each other General Engineering 12
Why does a piece of glass stick to another piece of glass? Introductory Physics Homework 5
The Schrodinger Equation solved piece by piece Quantum Physics 2
