Proof: if A is subset of B then closure of A is subset of closure of B
  • Thread starter Thread starter chessbrah
    closure Proof
The discussion revolves around a proof related to set theory, specifically addressing the relationship between the closure of a subset and the closure of its superset. Participants are exploring definitions and properties of closure in a mathematical context.
  • Some participants suggest using proof by contradiction, while others emphasize the importance of defining "closure" and "closed" sets. There is a mention of considering limit points as part of the reasoning process.
Participants are actively engaging with the problem, raising questions about definitions and suggesting different approaches. There is a recognition of the forum's guidelines regarding providing hints rather than complete solutions, which shapes the nature of the discussion.
Some participants express concern about the appropriateness of the thread's placement in the forum, indicating it may be perceived as a homework question. There is a call for clarity on the definitions being used in the proof.
chessbrah
I'm thinking proof by contradiction but I can't seem to get anywhere.
Think about limit points. x is in the closure of A, so it is a limit point of A...
You should probably state the definition of "closure" that you would like to use, and maybe also your definition of "closed". I like the definition that says that the closure of E is the smallest closed set that contains E. If we use that definition, the proof is very simple.
I see that you're new here. If you're wondering why we don't just tell you the complete solution, it's because the forum rules tell us not to do that when someone posts a textbook-style question. We are only allowed to give you hints, and tell you if you're doing something wrong.
It might be easier to prove that if A is contained in a closed set (here the closure of B, which follows since B is contained in the closure of B and A is contained in B), then the closure of A is contained in the same closed set.
May I ask why this thread is here? It isn't number theory, and it looks like homework to me.
I agree. I have moved the thread to "Homework and Coursework- Calculus and Beyond".
I also agree with Fredrik that you need to state what definition of closure you are using. One common definition is that the closure of a set, A, is the smallest closed set that contains A. Using that definition this theorem is pretty close to trivial.
  • · Replies 16 ·
