Writing Gravitation Force On Central Sphere In Unit Vector Notation
The discussion focuses on calculating the net gravitational force on a central sphere (mass m5 = 2.40 g) due to four surrounding spheres with masses m1 = 6.00 g, m2 = 3.00 g, m3 = 1.00 g, and m4 = 6.00 g, arranged in a square formation. Using Newton's Law of Gravitation, the calculated force is F = 1.46e-14 N, directed towards the m2 sphere. The final expression in unit-vector notation is F = 1.46e-14 N * (0.707i + 0.707j), indicating the force's direction in the x and y axes.
  • Newton's Law of Gravitation
  • Unit vector notation
  • Basic vector addition
  • Understanding of gravitational force calculations
  • Study gravitational force calculations using Newton's Law of Gravitation
  • Learn about unit vector notation in physics
  • Explore vector addition techniques in two dimensions
  • Investigate gravitational interactions in multi-body systems
Physics students, educators, and anyone interested in gravitational force calculations and vector notation in mechanics.
GingerBread27
In Figure 13-34, a square of edge length 21.0 cm is formed by four spheres of masses m1 = 6.00 g, m2 = 3.00 g, m3 = 1.00 g, and m4 = 6.00 g. In unit-vector notation, what is the net gravitational force from them on a central sphere with mass m5 = 2.40 g?
Well by using Newton's Law of Gravitation I get a single answer and I know it points towards m2 (or maybe I'm wrong). I just don't know how to write this in unit-vector notation.
I did F={(6.67e-11 m^3/kg*s^2)(.0024kg)(.003kg-.001kg)}/{(.148m)^2}
I get F=1.46e-14 N. I don't know if this is right, and if it is right I don't know how to put it in unit-vector notation.
Nevermind figured it out :)
Did you multiply by sin45/cos45 to get
F = <1.034E-14, 1.034E-14> ?
I was having the same difficultly...
In unit-vector notation, the net gravitational force on the central sphere with mass m5 = 2.40 g would be represented as:
Where i and j are unit vectors in the x and y directions, respectively. This represents the direction of the force, which, as you correctly calculated, points towards the m2 sphere. The magnitude of the force is given by the scalar value, 1.46e-14 N.
  • · Replies 17 ·
