Find all complex roots of polynomial
The discussion revolves around finding all complex roots of the polynomial equation x^4 - 6x^3 + 26x^2 - 46x + 65 = 0, given that 2 + 3i is one of the roots. Participants explore methods to identify the remaining roots.
  • Participants consider using polynomial division and the properties of complex roots, including the idea that complex roots come in conjugate pairs. There is discussion about confirming roots by substitution into the polynomial and exploring the implications of the polynomial's degree.
Some participants have provided hints and guidance on using polynomial division and the properties of complex conjugates. There is ongoing exploration of the correct roots, with some participants expressing confusion about their earlier attempts and the validity of their solutions.
Participants note the polynomial's degree and the requirement for four roots, which influences their reasoning about the number of complex roots. There is mention of incorrect assumptions leading to wrong answers, as well as the need to verify potential roots through substitution.
DryRun
Given 2 + 3i is one root of the equation:
x^4 - 6x^3 + 26x^2 -46x +65 = 0
Find the remaining roots.
The attempt at a solution
I am thinking about this as a possible solution although it is too long to be plausible, unless I'm wrong.
let x = a + bi and then replace in the polynomial. Then, expand and finally, divide it by 2+3i
Another possibility (i'm not sure) is this:
x (x^3 - 6x^2 + 26x -46) +65 = 0
So, i try to solve the cubic equation: x^3 - 6x^2 + 26x -46
However, note that one solution to x, is not equal to -65. So, this method is wrong, i believe.
I frankly don't know how else to go about to solve this one.
What other property about complex roots do you know? (Hint: they always come in pairs)
So, 2-3i is also a root? How do i confirm that? By replacing in the polynomial, it should equal zero, right?
But what about the other roots? Since the maximum power of x is 4, so i assume that there are 4 roots in all.
I still can't figure it out. Can someone please give me a hint?
If you have two roots p and q, then (x-p)(x-q) is a factor. Use long division to divide out that factor and see what's left.
Notice that when p & q are complex conjugates, (x-p)(x-q) can be written as a sum times a difference which comes out quite nicely as a difference of squares.
(x - (2-3i))(x - (2+3i)) = ((x-2) + 3i)((x-2) - 3i) = ...
OK, here is what i did:
The two known factors are: (2+3i) and (2-3i)
So, the product is: (2+3i)(2-3i) = x^2 - 4x + 13
Using this product as divisor and the polynomial as dividend, i get this:
x^2 - 2x + 5
OK, i got it. Thanks guys. :)
So, what are the two remaining roots?
Initially, i did it like this:
x(x-2) = -5
So x = -5 and x = -3
But then i don't know why but these answers are wrong (from the book).
So, i used quadratic formula
and i got these: 1-2i, 1+2i, which are correct from the book.
But again, i don't understand why i can't use the first set of simpler roots; -5 and -3.
x(x-2) = -5
You can't use -5 & -3 because they're not solutions of x(x-2) = -5. Plug them into see that.
Basic rule: If ab= 0 then either a= 0 or b= 0. But that is a special property of 0. You cannot say "if ab= -5 then either a= -5 or b= -5" which is what you were trying to do.
I think i have this one wrapped up. Thanks for the help. :)
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 27 ·
  • · Replies 18 ·
