How Do Torque and Hinge Placement Affect a Door's Stability?
  • Thread starter Thread starter foot
    Hinges Torque
This discussion focuses on the calculation of forces at the hinges of a door with a height of 2.1m and a width of 0.91m, supported by two hinges located 0.30m from the top and bottom. The door's mass is 27kg, leading to a vertical force of 13.5kg at each hinge due to gravity. To determine the horizontal components of the forces, the summation of torques around each hinge must equal zero, utilizing the distance of 0.30m from the hinge to the point of force application. The torque can be calculated using the cross product of the force and distance, and trigonometry can be employed to resolve the torque into its x and y components.
  • Understanding of torque and its calculation
  • Knowledge of unit-vector notation
  • Familiarity with the concepts of force and mass
  • Basic trigonometry for resolving components
  • Learn about the principles of static equilibrium in mechanics
  • Study the application of the cross product in physics
  • Explore detailed examples of torque calculations in rigid body mechanics
  • Investigate the effects of hinge placement on structural stability
Mechanical engineers, physics students, and anyone involved in structural design or analysis of door mechanisms will benefit from this discussion.
foot
I'm having quite a bit of trouble with this problem. It seems easy, but I just can't seem to get the idea.
The Problem said:
A door has a height of 2.1m along a y-axis that extends vertically upward and a width of 0.91 m along an x-axis that extends outward from the hinged edge of the door. A hinge 0.30 m from the top and a hinge 0.30 m from the bootom each support half the door's mass, which is 27kg. In unit-vector notation, what are the forces on the door at a) the top hinge and b) the bottom hinge.
I'm able to calculate the vertical components of the forces by using the summation of forces in the y direction equal to zero. The horizantal components, I'm pretty sure I need to use summation of torques, but there are only two forces! The force from each hinge in the horizantal direction! How would I go about solving htis?
You are given the vertical components of the force the hinges exert on the door. To find the horizontal components, take each hinge as a pivot point and realize that the torques about that point must add to zero.
It sounds like you are on the right track with using the summation of torques to solve this problem. However, in order to calculate the torque, you will need to know the distance from the hinge to the point where the force is applied. In this case, the distance is given as 0.30m.
To find the torque at the top hinge, you will need to use the force and distance in a cross product. The force will be the weight of half the door (27kg/2 = 13.5kg) multiplied by the acceleration due to gravity (9.8m/s^2) and the distance will be 0.30m. This will give you the torque in the horizontal direction, which can then be broken down into its x and y components using trigonometry.
Similarly, for the bottom hinge, you will use the same force and distance, but in the opposite direction (since the force will be acting in the opposite direction at the bottom hinge). Again, you can use trigonometry to break down the torque into its x and y components.
Remember, torque is a rotational force, so it is important to consider the distance from the hinge to the point where the force is applied. I would recommend drawing a diagram to visualize the problem and make it easier to solve.
I hope this helps you understand the concept of torque and how it relates to door hinges. Keep practicing and don't be afraid to ask for help if you are still having trouble. Good luck!
13K
  • · Replies 30 ·
9K
21K
