What is causing the segmentation fault in my program when reading a txt file?
  • Thread starter Thread starter nenyan
    Error Program
The segmentation fault in the program occurs due to incorrect usage of the fscanf function when reading values into the skydata structure. The original code attempts to directly assign values to the structure members without using the address-of operator (&), leading to undefined behavior. The correct implementation requires modifying the fscanf line to include the address-of operator, ensuring proper memory access. Additionally, memory allocation should be checked for success to prevent potential crashes.
  • C programming language fundamentals
  • Understanding of pointers and memory management in C
  • Familiarity with file I/O operations in C
  • Debugging techniques using tools like GDB
  • Learn about memory allocation and deallocation in C using malloc and free
  • Explore the use of the GDB debugger for tracking segmentation faults
  • Study the correct usage of fscanf and other file reading functions in C
  • Investigate best practices for error handling in C programs
C programmers, software developers debugging memory issues, and anyone working with file I/O in C.
nenyan
I wrote a program to read a txt file. When its running, system appear "Segmentation fault <core dumped>"
the code:
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#define BUF 1024
#define pi 3.14159
typedef struct skymapdata
double ra;
double dec;
double p;
double pn;
} skydata;
/* This function is for readding skymap*/
int
readskymap( FILE *fp, skydata **sky)
skydata *sky1;
int i=0, n=BUF; /* n is the buffer. */
if ( !(*sky=(skydata *)malloc(n*sizeof(skydata))))
printf("memory error 1\n");
while (!feof(fp))
{ fscanf(fp, "%lf %lf %lf %lf", (*sky+i)->ra, (*sky+i)->dec, (*sky+i)->p, (*sky+i)->pn);
i++;
if (i==(n-1)) /*the number of lines is going to be longer than buffer. */
if(!(sky1=realloc(*sky, 2*n*sizeof(skydata))) ) {
printf("memory error 2\n"); }
*sky=sky1;
n*=2; } /*double the buffer*/
return i; /* Returning i tell us the accurate number.*/
int
main()
int i, n1;
skydata *sky;
FILE *fp;
if ( !( fp=fopen("skymap.txt", "r"))) {
printf ("cannot open the skymap.txt file\n");
return 1;}
n1=readskymap(fp, &sky);
for (i=0; i<n1; i++)
printf("%e %e %e %e\n", sky.ra, sky.dec, sky.p, sky.pn);
skymap.txt:
3.222 4.323 0.23 0.32
5.434 43.34545 0.3434 0.22
Technology news on Phys.org
the code:
Hello nenyan.
For future posts you should embed your code in code tags. Basically use CODE and /CODE with [ and ] around the tags. I will use this so that I can see a cleaned up version of your code:
Code:
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#define BUF 1024
#define pi 3.14159
	double ra;
	double dec;
	double p;
	double pn;
} skydata;
int
	skydata *sky1;
	while (!feof(fp))
	i++;
		*sky=sky1;
}int
main()
	int i, n1;
    skydata *sky;
	FILE *fp;
		return 1;}	n1=readskymap(fp, &sky);
		printf("%e %e %e %e\n", sky[i].ra, sky[i].dec, sky[i].p, sky[i].pn);
skymap.txt:
Have you run this through a debugger? What line does it crash on?
I'm thinking that maybe you are passing by reference when you should be passing by value, or passing by value when you should be passing by reference.
To check this you could create some temporary pointer variables for your *(sky+i) and in the debugger make sure that all of these pointers have the right contents.
Also in terms of allocating your memory for your sky data structure, zero the memory and then check while you are debugging that the memory is indeed zeroed and also the right size.
I found the reason.
should be
fscanf(fp, "%lf %lf %lf %lf", &((*sky+i)->ra), &((*sky+i)->dec), &((*sky+i)->p), &((*sky+i)->pn));
  • · Replies 22 ·
