How Do You Find and Prove a Critical Point in Thermodynamics?
The discussion revolves around understanding how to find and prove a critical point in thermodynamics, particularly in the context of an exam question posed by a professor. Participants explore the definitions and implications of critical points, specifically in relation to phase transitions and the behavior of substances like water.
  • Homework-related
  • One participant seeks guidance on how to find and prove a critical point, noting a lack of information in their textbook and homework problems.
  • Another participant suggests starting with the definition of a critical point and determining if the situation meets that definition, indicating a need for more context on the problem.
  • A participant describes the critical point as the condition beyond which a substance does not exhibit phase transitions, specifically mentioning water and its behavior as a supercritical fluid.
  • There is a discussion about the mathematical condition dP/dV = 0 being a key aspect of identifying a critical point, but one participant argues that proving a critical point is more about satisfying the definition rather than a formal proof.
Participants express differing views on whether a critical point can be "proven" or if it is simply observed. There is no consensus on how to approach the problem or what constitutes sufficient proof.
Participants note limitations in their resources, including vague lecture notes and minimal textbook coverage on critical points, which may affect their understanding and ability to solve related problems.
Spoolx
1. Find Critical Point and Prove it
2. dP/dV =0
3. n/a
Hey guys, so our professor was talking about critical points in class. He mentioned on our exam we would have to find a critical point and prove it.
Anyhow none of our homework problems ask this, and very little info in the book demonstrates this.
I am not asking for a specific question but basically how would I go about solving a problem like this? I know the critical constants are in the Thermodynamic Tables.
But if my professor asked for the critical points I would go to those tables, not sure how I would calculate them or prove them.
Any help is appreciated (I apologize if this is in the wrong forum)
Thanks
As far as proofs go, I would start with the definition he gave of a critical point. You then need to show the situation satisfies the definition. Beyond that you've given very little to go on. What are you given from which to prove/find a CP?
Thats the thing, he really never said.
His exact words were.
"On your midterm you will be expected to find the critical point and prove it"
In the lecture notes he only mentions dP/dV = 0
In the book it mentions very little about the critical point and tells us to use the tables to find it.
I foresee his question being (although I am just guessing, this is what I am expecting.)
"Find the critical point of water, and prove it"
The critical point is the point beyond which a substance ceases to have a phase transition boundary. I.e. for water beyond a certain pressure and temperature which is its critical point its phase is that of a supercritical fluid where it will no longer transition to a conventional gas under increasing temperature nor to a conventional liquid or solid under increasing pressure.
The distinguishing feature is as you've cited the ability to compress without change in pressure (given fixed temperature), dP/dV=0.
One doesn't prove a critical point but rather observes it. The only "proof" I can imagine is an argument that the definition is satisfied so understand the definition.
Especially look at the definition of a http://en.wikipedia.org/wiki/Supercritical_fluid" .
  • · Replies 157 ·
14K
