Finding the magnitude of acceleration
The discussion focuses on calculating the magnitude of acceleration in a physics problem involving two blocks, M1 and M2. The key equations used are F=ma and ΣFx=ma, where ΣFx represents the sum of forces acting on the blocks. The participant identifies tension and friction as the primary forces acting on block M1, emphasizing the need to calculate friction using the normal force and the coefficient of friction. The participant successfully solved parts (a) and (b) of the problem but seeks assistance with part (c), specifically regarding the total forces acting on M1.
  • Understanding of Newton's Second Law (F=ma)
  • Knowledge of force components (ΣFx)
  • Familiarity with friction calculations (normal force and coefficient of friction)
  • Basic problem-solving skills in physics
  • Study the concept of tension in connected systems
  • Learn about calculating net forces in multi-body problems
  • Explore the relationship between normal force and gravitational force
  • Review examples of friction in physics problems
Students studying physics, particularly those tackling mechanics problems involving forces and acceleration, as well as educators seeking to enhance their teaching methods in these topics.
Include
Problem one on this pdf file.
http://www.dtfizzix.com/APEXAMS/Phackets/B-1987-Exam.pdf
F=ma
ΣFx= ma
ΣFx= (m1+m2)a
What are the total forces on of the block labeled M1?
Tension, and friction, in opposite directions. To find tension, look at block B. To find friction, multiply the normal force by the coefficient of friction. Since there is no vertical acceleration of block A, that means that there must be no net vertical force, so what does this say about the normal force?
That the normal force must equal the gravitational force?
I've solved the problem (a) and (b).
Now I need help with problem (c). What are the total forces acting on M1?
Is it the mass of M2 minus the coefficient of friction of M1?
  • · Replies 24 ·
12K
