Can anyone tell me the basics of Quasar?Note: Means that how it is
  • Context: Graduate
  • Thread starter Thread starter vinayjain
    Basics Means
The discussion centers on the nature and characteristics of quasars, including their formation, the processes involved in their emissions, and the fate of quasars as they evolve into quieter states. Participants explore the relationship between quasars and supermassive black holes, as well as the implications for galaxies like the Milky Way.
  • Some participants propose that quasars are outputs of supermassive black holes that emit immense radiation due to infalling matter.
  • Others discuss the acceleration of atoms near the event horizon, leading to high-energy photon emissions.
  • There are questions regarding what happens to a quasar after it exhausts its emissions, with some suggesting it becomes a "quiet" black hole.
  • Participants explore the nature of a silent black hole, discussing its ability to pull in matter and potentially become active again.
  • Some participants express confusion about how radiation can escape a black hole's influence, particularly from the accretion disk surrounding it.
  • There is a discussion about the effects of quasar jets on surrounding stars and whether they could destroy stars in their path.
  • One participant speculates whether the Milky Way could have been a quasar in the past, leading to its current state as a galaxy with a supermassive black hole at its center.
Participants express a range of views, with no consensus on several points, particularly regarding the implications of quasar emissions and the fate of galaxies. Some questions remain unresolved, and participants challenge each other's interpretations.
Some claims depend on assumptions about the behavior of matter near black holes and the nature of quasar emissions, which are not fully resolved in the discussion. The relationship between quasars and galaxy formation is also a complex topic with varying interpretations.
vinayjain
Note: Means that how it is created when there is only one dimension exists in a black hole and what is the reaction that occurs which emits so much light that it can be seen through millions of light year.
Astronomy news on Phys.org
A quasar is believed to be the output of a well fed, supermassive black hole. Infalling matter is shredded by the black hole and emits immense amounts of radiation.
can it be a bit more ellaborative?
Atoms accelerate to incredible velocities as they approach the event horizon. Collisions between these accelerated atoms result in highly energetic photon emissions.
what will going to happen when a quasar completes its life of emmision?
It becomes a "quiet" black hole like the one at the center of our galaxy.
What is the nature of a silent black hole?
Means will it going to pull things around it and after gattering enough element it will again become quasar or it is something else.
It means that there is current little to no material falling into the black hole, meaning that there is little to no emissions from the accretion disk, if there is one still. If a star is suddenly perturbed and is sent into an unstable orbit around it, eventually being shredded and falling in, then the black hole would no longer be silent.
In general, most if not all galaxies are thought to contain supermassive black hole's that went through some quasar phase (including our own Milky Way) at some point in the past. We think this is true because there are large-scale galaxy characteristics that correlate with the mass of the supermassive black hole. These large-scale properties span many thousands of light years well beyond the gravitational influence of the black hole, and are related to http://en.wikipedia.org/wiki/M-sigma_relation" .
Can anyone please clarify my doubt...
What I have read about the power source of the quasar is the supermassive black hole at the centre of the quasar which has a mass of million or even billion times the mass of sun...At the center of a quasar, the black hole is surrounded by a large, rotating cloud of gas. As the gas falls into the black hole, it is heated up to millions of degrees. The gas emits thermal radiation due to its enormous heat. This thermal radiation spans the spectrum, making the quasar bright in the visible spectrum as well as x-rays.
Now when not even light can pass through a black hole as its escape velocity is more thn the speed of the light than how could these radiation comes out and illuminates quasar.
You have it about right. The point that you are missing is that the large rotating cloud of gas (which is called the 'accretion disk') is well outside the event hroizon of the black hole. So radiation emitted from this accretion disk can still leave the vicinity of the black hole and be seen by external observers. Eventually all of the matter that is feeding the accretion disk falls into the event horizon, and then the black hole goes quiet, like the one at the center of our galaxy.
Please clarify my other doubt which come from this statement....This means that at some point of time our galxy also have a quasar at the centre...so now what i have read about a quasar is that it emits jets while a quasar is in running status and these jets destroy everything in path to some extent then how come our galaxy stars are not affeted by that and if thy were affected then how come there is no residual of those stars found floating here and there in the galaxy
The jets are usually not in the plane of the galaxy, but near perpendicular to it, meaning that most of the galaxy is not touched by them. Also, even if there were plenty of stars in the way of the jets, enough time has passed that new stars could have formed to replace those lost or that other stars were perturbed in their orbits and "migrated" to a new orbit similar to destroyed stars. Also, the jets don't exactly "destroy everything in their path". At a distance of 33 light years, the brightest quasar seen yet would look as bright as the sun. That is far from the needed intensity to destroy anything that has already formed, such as stars. Over time the jets can push gas and dust outward, but not destroy stars unless they are extremely close.
Is it possible that our milky way was he quasar at some point and when the fuel goes off it is made like this and we get a supermassive black hole at the centre and if it can be true than the quasar which is now known as milky way would be a part other galaxy which has expanded far beyond than milky way and we are not able to recognise...please clarify
I can't understand what you're asking, none of it makes any sense.
I am asking that it is said many a times that when a quasar ceases it becomes a galaxy so i am asking that is it possible that our milky way galaxy is formed when a quasar ceased and left a supermassive black hole at the centre which is there in our galaxy...
I don't know what you read that said galaxies only form after quasars, that isn't true. Supermassive black holes form during the initial galaxy formation process. A quasar is nothing but a very active black hole of a galactic nucleus. Quasars don't cease and leave behind a black hole, it a quasar only occurs because there is already a black hole there to cause the accretion disc to form.
These quaar mysteries are
How so?
Drakkith said:
How so?
because what exactly is going on there we didn't know
Perhaps I misunderstood your "Yuck" smiley.
cn anyone please tell me that what probably happen to a black hole when its life is complete
just curious about something: when there are no dimensions exists near the centre of black hole and singularity comes when u go closer and closer at the centre of the black hole so every matter which is merged inside the black hole cannot increase the mass of the black hole as it is like the matter is destroyed to make it dimensionless so how does a black hole increase its mass during its phase of life......
Where does it say that dimensions disappear inside a black hole?
sorry I actually misunderstood something......but actually want to know something else i.e.
The expansion of our universe is going on increasing day by day and since its speed is increasing there might be time coming in future that its expansion speed will cross the speed of light and in that case visualizing any object in the universe will become impossible is that true....
Expansion is not a speed, it is a rate. It is already the case that galaxies beyond a certain distance from us (Tens of billions of light years I think) are receding at a velocity greater than c. HOWEVER, this is because space is being created (or expanding) in between us and "carrying" the galaxy away from us. If we could cut away all the space between our 2 galaxies both would be traveling through local space at a similar velocity. This is why it doesn't break relativity, because it is not traveling THROUGH space at greater than c.
See here: http://en.wikipedia.org/wiki/Metric_expansion_of_space
