Finding the maximum or minimum value of a funtion to the nth degree?
The discussion revolves around finding the maximum or minimum values of polynomial functions of degree n, particularly focusing on higher degrees such as cubic (x^3), quartic (x^4), and beyond. Participants explore whether the methods used for quadratics can be applied to these higher-degree functions.
  • Participants question the applicability of known methods for quadratics to higher-degree polynomials. There are inquiries about the restrictions of domain or range and the nature of the polynomial in question. Some discuss the potential number of x-axis crossings based on the degree of the polynomial.
The discussion is ongoing, with participants sharing insights about the role of calculus in finding extrema and the importance of understanding graph behavior. There is acknowledgment of the limitations of non-calculus methods for determining local maxima and minima.
Some participants express uncertainty about the specific characteristics of higher-degree polynomials compared to quadratics, and there is a mention of the need for further knowledge before fully addressing the problem.
Painguy
How do i find the maximum or minimum value of a function to the nth degree? We've only done this for a quadratic function/equation in my class, but how would u find this for a higher degree such as x^3, x^4 or x^n? Does it follow the pattern of a power function in that x^4 is similar to x^2?
Are you restricted to a domain or range for this? Is it a polynomial of degree n?
The number of times the graph of a polynomial can [potentially] cross the x-axis is equal to its degree. So something of degree 4, for example, may cross the x-axis up to 4 times. You already know that a straight line cuts just once, and a circle or parabola crosses up to two times.
As for finding local max and min without calculus, hmmm ...
Haha I see :-p Never mind then. I suppose i can wait until i know more. Thx for the other explanation though. :smile:
Calculus is good at finding maximum and minimum values of functions, it's one of its most useful functions. Without calculus, you have to basically draw the graph or look at the form of the equation to see where the minimum value will occur. But learning about graphs will help with calculus later, because you can't rely on formulas all the time :).
x^4 looks a little different from x^2, if my memory serves me correctly.
Normally a function of nth degree has at most n-1 turns.
  • · Replies 21 ·
