Please help with these Quantum theory Qs please
This discussion focuses on solving two quantum theory problems related to de Broglie's hypothesis and the resolving power of microscopes. The first problem involves calculating the maximum speed of a 76.00 kg student passing through an 85.00 cm doorway to achieve significant diffraction, requiring the wavelength to be greater than 8.5 cm. The second problem addresses the minimum kinetic energy required for electrons in an electron microscope to resolve an atom at 15 pm, along with the necessary photon energy for the same resolution.
  • Understanding of de Broglie's hypothesis and wavelength calculation (h/p)
  • Knowledge of momentum and kinetic energy relationships
  • Familiarity with electron microscopy and photon energy concepts
  • Basic principles of wave-particle duality in quantum mechanics
  • Calculate de Broglie's wavelength for various particles using h/p
  • Explore the relationship between momentum, speed, and kinetic energy in quantum systems
  • Investigate the principles of electron microscopy and its applications in atomic resolution
  • Learn about photon energy calculations using Planck's constant and wavelength
Students and educators in physics, particularly those studying quantum mechanics, wave-particle duality, and microscopy techniques. This discussion is beneficial for anyone looking to deepen their understanding of diffraction and resolution in quantum systems.
Yuelao
If someone could kindly spare some time and point out how to do these questions, most greatful.
1.After learning about de Broglie's hypothesis that particles of momentum, p, have wave characteristics with wavelength, h/p, a 76.00 kg student has grown concerned about being diffracted when passing through a doorway that is 85.00 cm wide. Assume that significant diffraction occurs when the width of the diffraction aperture is less than 10.0 times the wavelength of the wave being diffracted.
a) Determine the maximum speed at which the student can pass through the doorway so as to be significantly diffracted.
? m/s
b) With that speed, how long will it take the student to pass through the doorway if it is 15.0 cm thick?
? s
2. The resolving power of a microscope depends on the wavelength used. If one wished to use a microscope to "see" an atom, a resolution of about 15 pm (pico-meters) would have to be obtained.
a) If electrons are used (in an electron microscope), what minimum kinetic energy is required for the electrons? (Assume the electrons are non-relativistic.)
? eV
b) If photons are used, what minimum photon energy is needed to obtain the required resolution?
? eV
Thanks in advance~
? m/s
? s
The problem is rather stupid,but here goes:
a)His de Broglie's wavelength should be larger than 8,5cm ,which should correspond to a certain momentum.Knowing the momentum and mass of the diffracted body,u can find the speed.
b)Knowing the speed and length,u can simply find the time required.
? eV
? eV
Thanks in advance.
a)From de Broglie's formula,find the momentum and with the momentum and the mass,u can easily find the kinetic energy.
b)The same.If you have the wavelength,and knowing the speed of light and Planck's constant,u can easily find the energy.
ah~ pretty simple stuff, thanks for the advice, i'll go try do it now.
9K
  • · Replies 36 ·
10K
