How do you solve the integral ∫√(a² - x²) dx using substitution?
  • Thread starter Thread starter Masschaos
    Integral
The discussion revolves around the integral ∫√(a² - x²) dx, which is approached through substitution methods. Participants are exploring the implications of using trigonometric identities and substitutions in the context of integral calculus.
  • Participants discuss the substitution u = sin⁻¹(x/a) and the resulting expressions for dx and √(a² - x²). There is confusion regarding whether the integral should be expressed as ∫a*cos(u) du or ∫a²*cos²(u) du, with various attempts to clarify the correct form.
The discussion is active, with participants questioning the correct formulation of the integral after substitution. Some guidance has been offered regarding the need to express everything in terms of u, including the differential, but no consensus has been reached on the final expression.
Participants are grappling with the transition from dx to du in their substitutions, and there is a noted reliance on external sources, such as Wolfram Alpha, which adds to the complexity of their understanding.
Masschaos
∫√(a2 - x2) dx
What I've understood so far is its a substitution integral.
Through the instruction of my lecture notes, I have
∫√(a2 - x2) dx Let u = sin-1(x/a)
x = a*sin(u)
dx = a*cos(u)
This means that √(a2 - x2) = √(a2 - a2sin2(x))
Then as the trig identity of √(cos2(u) + sin2(u)) = 1.
You can rearrange it to give cos(u) = √(1-sin2(u))
So √(a2 - a2sin2(u)) = √(a2 * cos2(u)) = a*cos(u)
Now there is my problem, A lot of other sources say that rather than ∫a*cos(u) du
it is ∫a2 * cos2(u) du
and I don't understand why.
Masschaos said:
∫√(a2 - x2) dx
x = a*sin(u)
dx = a*cos(u) du[/color]
OK, so you rewrote the radical in terms of u, so at this point you have
[tex]\int \sqrt{a^2-x^2}\,dx = \int a\cos u\,dx[/tex]Note that the integral still has dx in it, not du.
So it is ∫a*cos(u) dx and not ∫a2 * cos2 (u) dx?
I'm just struggling as I don't understand why some people are using ∫a2 * cos2 (u) dx.
I've checked on wolfram Alpha also, and there is also the ∫a2 * cos2 (u) dx and I can't reconcile this from my above working.
Masschaos said:
So it is ∫a*cos(u) dx and not ∫a2 * cos2 (u) dx? I'm just struggling as I don't understand why some people are using ∫a2 * cos2 (u) dx.
You still have the dx in there. From your first post, what does dx =? Put it in terms of du.
Yes, but you don't want it to be that- you want everything in terms of u, not x.
NO, it isn't! Look again! You cannot change everything except the differential to u but leave the differential as "dx".
With the substitution x= asin(u), dx= d(asin(u))/du du= acos(u)du.
Now, you have both [itex]\sqrt{a^2- x^2}= \sqrt{a^2- a^2sin^2(u)}= \sqrt{a^2cos^2(u)}= a cos(u)[/itex] (as long as we are careful about signs) and [itex]dx= a cos(u)du[/itex]. Putting those together, [itex]\int\sqrt{a^2- x^2} dx= \int (a cos(u))(a cos(u)du)= a^2\int cos^2(u)du[/itex].
Oh of course!
I can't believe I didn't see that.
Thank you very much!
  • · Replies 22 ·
