Need help w/ centripetal acceleration lab questions
This discussion revolves around questions related to centripetal acceleration, particularly in the context of a lab experiment involving circular motion. The original poster presents three questions, including the necessity of an unbalanced force for circular motion, the relationship between centripetal acceleration and radius, and a specific scenario involving an amusement park ride.
  • Participants explore the reasoning behind the need for an unbalanced force in circular motion and discuss the implications of changing radius on centripetal acceleration. There are attempts to calculate centripetal acceleration based on given parameters, and questions arise regarding the interpretation of the second question.
The discussion is active, with participants sharing their reasoning and calculations. Some guidance has been offered regarding the interpretation of the questions, particularly in relation to the physics concepts involved. There is an ongoing exploration of the relationships between velocity, radius, and acceleration.
Participants express uncertainty about the interpretation of the second question and the calculations related to the experience of g-forces in the amusement park ride scenario. The discussion reflects a mix of understanding and confusion regarding the concepts of centripetal acceleration and the forces involved.
ballahboy
These questions are from a lab we just did.
1. Why is an unbalanced force required to produce circular motion?
2. The ratio of squared velocity to radius is a constant. In other words, the centripetal acceleration did not change as the radius changed. Explain.
3. In an amusement park ride called the spinout, riders are positioned against the inside wall of a rotating drum. The drum begins to rotate and after a certain rotational speed is reached, the floor is lowered and the riders remain in position and do not fall. The diameter of the chamber is 4.3 meters and the period of rotation is 1.7 seconds. What is the centripetal acceleration of the rider? Approximately how many g's does the rider experience?
For this one, i got centripetal acceleration to equal 29.4m/s^2. Not sure if its correct but i don't know how to find the second part of the question.
Have you thought about the first two questions? Show us a little of what you have reasoned through and your process for #3.
Um.. i wasnt sure about how to do #1 and 2 so i asked. And for #3 i found the velocity by using 2pi*r/t and got 7.95m/s. Then i used centripetal acc.=v^2/r and got 29.4m/s^2. Wasnt sure what the second question is asking.
1. When something is moving in circular motion, it is constantly changing direction. Since velocity is a vector quantity, it has both magnitude and direction. What can you, therefore, conclude about objects in circular motion?
Now also consider that [tex]\vec{F}_{net}=m\vec{a}[/tex]
2. This comes from [tex]\vec{a}_{centripetal}=\frac{\vec{v}^{2}}{r}[/tex]. Basically what happens is acceleration doesn't change because when you change the radius the velocity changes as well, making velocity squared divided by radius a consant (acceleration).
You also know that [tex]\vec{F}_{centripetal}=\frac{m\vec{v}^{2}}{r}[/tex], and [tex]\vec{F}_{net}=m\vec{a}[/tex]. Can you explain what is happening?
3. Didn't check your answer but your method looks correct. For the second part, g=9.81 m/s^2, so how many "g"s do the people experience?
  • · Replies 16 ·
