Are the Outer Bands of Galaxies Moving Faster Than the Speed of Light?
  • Context: Graduate
  • Thread starter Thread starter DaddyJax
    Galaxies Speed
The discussion revolves around the speeds of the outer bands of galaxies and whether they can exceed the speed of light, considering various factors such as galaxy rotation, space expansion, and relative motion. It explores theoretical implications and relativistic effects without reaching definitive conclusions.
  • One participant questions if the outer bands of galaxies are moving at or faster than the speed of light, suggesting that if all motions (galaxy rotation, space expansion, etc.) align, the resultant speed could exceed light speed.
  • Another participant counters that the outer bands are moving much slower than light, noting that our galaxy takes over 230 million years to complete one rotation.
  • Some participants discuss the concept of relative motion, indicating that speeds are meaningful only in relation to a point of reference, and provide examples involving velocities approaching the speed of light.
  • A participant introduces an analogy comparing galaxy motion to a spinning carnival ride, emphasizing the complexity of combined motions.
  • There is a discussion about the relativistic addition of velocities, with one participant explaining that speeds do not simply add linearly at relativistic speeds, referencing the Lorentz transform.
  • Another participant raises a hypothetical scenario about measuring the speed of a planet orbiting a star from a stationary position in space, questioning if that speed could exceed light speed.
  • Responses indicate that even under various hypothetical conditions, speeds measured will not exceed the speed of light, emphasizing the principles of relativistic velocity addition.
Participants express differing views on the speeds of galaxy outer bands and the implications of relative motion, with no consensus reached on whether these speeds could approach or exceed the speed of light.
The discussion includes assumptions about reference frames and the effects of relativistic speeds, which are not fully resolved. The complexity of measuring speeds in a relativistic context is acknowledged but remains open to interpretation.
DaddyJax
I am wondering about the speed of the outer bands of galaxies and if they are moving at or faster than the speed of light?
And then the thought of the speed of space expansion and and the body of the galaxy moving and the rotation of planets around the stars(solar system) and the spin of the planets themselves. If these were all to move in the same direction at the same time, how fast would that be (if you were on the planet)? Got to be moving faster than the speed of light.
Or does the proximity of mass negate these?
Particles in the accelerator at just below the speed of light only adding the rotation of the Earth would qualify, right?
Space news on Phys.org
what? No. They're moving quite slow indeed. Our galaxy takes more than 230 million years to complete one rotation.[/QUOTE]
No. Nowhere near.
Also, speeds are only meaningful when relative to point of reference. From the PoR of a rogue planet speeding through intergalactic space at .9c, our galaxy is indeed moving at .9c.
Thank you for the response!
Due to the size of the galaxy and the distance covered on the outer bands I wasnt sure.
I was thinking about the speed of everything included like the ride at Disney with the tea cups or at the carnival. The tea cup spins and it is on a disc that spins and it is on an even larger disc that spins and when you reach the outside of all three you are really moving!
I know.
The simplest model for this is a rocket flying along at .9c that fires a missile at .2c.
Does the missile travel at 1.1c? No.
Velocity at relativistic speeds is not linear, it uses what's called the Lorentz transform. The addition of two velocities will always result in a value less than c.
The missile's velocity (from an external point of view) will be somewhere between .9c and c (not inclusive).
So would a person who is running at 15mph on a conveyor belt that is moving at 15mph only be traveling at 15mph or 30mph?
From what frame of reference?
Obviously, from the FoR of someone stationary wrt the road on which a pickup carrying the treadmiill is driving - but it is important that we define what FoR we are using.
If we use the correct Lorentz transform then the speed of the walker would be a vanishingly small smidge less than 30mph.
I guess for this I am thinking about space and the point being a stationary position in space (allowing for the expansion) and watching a galaxy go by and rotating. If I was to measure the distance covered by a planet orbiting a star on tip of an outer band of a galaxy from that stationary position would that speed exceed the speed of light?
Not even close. I doubt it would be any significant portion of c.
No but let's grant that you do manage to find the right combination of snowball thrown from a moving train on a planet orbiting clockwise while going around its clockwise.
You will not ever measure the other object as moving faster than c. Your measurement will always be a fraction of c. This is how velocity addition works in our relativistic world.
Thank you for your responses!
Moderator's note: I have removed posts I consider not relevant to this thread, as well as responses to them.
  • · Replies 19 ·
  • · Replies 33 ·
  • · Replies 17 ·
  • · Replies 32 ·
  • · Replies 21 ·
  • · Replies 27 ·
