How Do You Calculate the Corrosion Rate of an Iron Sample?
  • Thread starter Thread starter FaNgS
    Corrosion Rate
The corrosion rate of an iron sample measuring 10mm x 20mm x 2mm exposed to a corrosive environment is calculated using Faraday's Law. For both surfaces exposed, the corrosion rate is determined to be 13.02 mm/year, based on a weight loss of 40.99 g/year and the density of iron at 7.87 g/cm³. When only one side is painted and not exposed, the corrosion rate remains the same at 13.02 mm/year due to the calculation method used, which inadvertently cancels out the effect of surface area. The discussion highlights the importance of correctly interpreting surface area in corrosion calculations.
  • Understanding of Faraday's Law in electrochemistry
  • Knowledge of corrosion processes and rates
  • Familiarity with unit conversions, particularly between mm² and cm²
  • Basic skills in algebra for manipulating equations
  • Study the principles of electrochemical corrosion and its measurement techniques
  • Learn about Tafel plots and their application in corrosion current determination
  • Explore the effects of surface area on corrosion rates in different environments
  • Investigate methods for protecting metals from corrosion, such as coatings and galvanization
Students and professionals in materials science, chemical engineering, and corrosion engineering who are involved in corrosion rate calculations and metal protection strategies.
FaNgS
Iron sample with dimensions 10mm x 20mm x 2mm is exposed to a corrosive environment (neglect thickness for surface area). Both sides of the sample are exposed to corrosive environment. Given http://i.imgur.com/tGRw4.jpg"
(a) Calculate corrosion rate mm/y
(b) Calculate corrosion rate if one of the sample surfaces is painted (not in contact with corrosive environment)
M=56g,
t=3.1536e7 sec/yr
number of electrons taking part n=2
F=96500C
density=7.87g/cm3
A=10*20=200mm2
From Faraday's Law: W=MtI/nF (W=weight loss, I=current in this case corrosion current)
(a) From Tafel Plot log(Icorr)=0.05mA/cm2 so Icorr=1.12e-3 A/cm2
I want to convert Icorr to just units of A, but since both surfaces are exposed should I multiply it by double the surface area?
i.e.: Icorr=1.12e-3*200mm2*2*(1cm/10mm)^2 = 4.48e-3 A
substituting in W=Mt*Icorr/nF = 40.99 g/yr
Corrosion Rate CR=W/density*Surface Area
Again I multiplied the Surface Area by 2 because both sides of the Iron sample is exposed
CR=(40.99g/yr)/[(7.87g/cm3)*(200mm2*2)*(1cm/10mm)^3)]=13.02mm/yr
(b) For only one side exposed:
I'm going to use half of Icorr since only 1 side is exposed so Icorr=2.24e-3 A
then W=20.49g/yr
Using only 200mm2 as the surface area
CR=(20.49g/yr)/[(7.87g/cm3)*(200mm2)*(1cm/10mm)^3)]=13.02mm/yr
I get the same corrosion rate...is this correct?
I believe the issue is with the surface area, I'm not sure if it effects the Icorr?
I interpret
as CR=(W/density)*Surface Area, but in
you have CR=W/(density*Surface Area)
Certainly you should not be doubling the area twice. Because of the above error, the two doublings cancelled.
