Breit Frame of reference ( Brick Wall )
The discussion focuses on the Breit frame of reference in the context of elastic scattering, specifically addressing Griffiths problem 3.21 from the first edition. The user successfully calculated the energy of particle A in the Breit frame using the invariant 4-vector dot product of energy-momentum. However, they seek assistance with determining the direction and magnitude of the Breit frame, emphasizing the two-dimensional nature of the problem and the relationship between the momenta projections before and after scattering.
  • Understanding of the Breit frame of reference in particle physics
  • Familiarity with elastic scattering processes
  • Knowledge of invariant 4-vector dot products
  • Basic concepts of momentum conservation in two dimensions
  • Study the properties of the Breit frame in particle collisions
  • Explore the concept of invariant mass and its applications in scattering problems
  • Learn about momentum conservation laws in two-dimensional scattering
  • Investigate examples of elastic scattering problems in particle physics
Students and researchers in particle physics, particularly those studying scattering processes and the application of the Breit frame in theoretical problems.
manofphysics
Breit Frame of reference ("Brick Wall")
I am having a lot of trouble understanding breit frame of reference.I was trying to solve griffiths problem 3.21 (1st ed.):
Consider elastic scattering- A+B----->A+B If particle A carries energy E, and scatters at an angle theta in the CM,
a) what is it's energy in the breit frame
b)Find the direction and magnitude and direction of breit frame.
I did do the first part by using the fact that in breit frame, (p before)= -(p after) and using the invariant 4 vector dot product of energy-momentum.
I am flummoxed by the b part.Any hints will be greatly appreciated.
This is clearly a 2-dimensional problem (everything remains in one plane). Let us think about the problem without any calculation. Can you tell something about the projections of A momenta (before and after) along different directions ? Is there a special direction in which the projections are equal ? Is there another direction in which the projections are opposite ? What is the angle between those two special directions ?
  • · Replies 86 ·
9K
  • · Replies 17 ·
