Understanding Landau Level Broadening in Magnetic Fields
  • Context: Graduate
  • Thread starter Thread starter Muneer QAU
    Broadening Landau
The discussion revolves around the concept of Landau level broadening in magnetic fields, particularly in the context of magnetotransport and its relation to impurity scattering and Anderson localization. Participants explore the implications of these phenomena in two-dimensional electron systems.
  • Some participants describe Landau level broadening as the spreading of energy levels due to weak disorder, leading to a non-degenerate density of states.
  • It is noted that in a magnetic field, the transverse momentum of electrons is quantized into discrete Landau levels, which are separated by the gyromagnetic frequency.
  • One participant mentions that Anderson localization occurs in this context, where the localization length diverges logarithmically, although the discussion acknowledges that real samples are finite and exhibit different transport properties.
  • Another participant seeks clarification on the term "scope of energy level," indicating a need for further elaboration on this concept.
  • Impurity scattering is discussed as a mechanism that can trap electrons, causing them to bounce between impurities, which is linked to Anderson's work.
  • A separate thread of discussion emerges regarding the separation of real and imaginary parts of complex numbers, with participants discussing the Cauchy principal value and its implications in mathematical contexts.
Participants express varying levels of understanding regarding Landau level broadening and Anderson localization, with some seeking clarification while others provide technical insights. The discussion on complex numbers introduces a different topic, indicating a lack of consensus on the initial question.
The discussion includes references to advanced concepts such as Anderson localization and the mathematical treatment of complex numbers, which may require specific background knowledge for full comprehension. Some assumptions about the participants' familiarity with these topics are evident.
Muneer QAU
what is meant by landau level broadening in a magnetic field?
The scope of energy level get large.
In a magnetic field, the transverse momentum of electrons are quantised into discrete Landau levels, separated in energy by the gyromagnetic frequency. Each level actually contains a continuum of states. In the presence of weak disorder, this continuum of states spread out (in energy) and gives rise to a non-degenerate density of states. Since these states are two dimensional, Anderson localisation occurs, i.e. the localisation length diverges (logarithmically). However, since in reality the samples are not infinite in extent, in each "blob" which comes from one Landau level, the middle region will still be spatially extended sufficiently to perform transport, but the edges will be insulating states.
thanks Genneth for this reply i am working on magnetotransport and have encounter with this term of Landau Level Broadening. i do not have idea of Anderson Localization please can you explain it simple term i read that landau level broadening occur due to impurity scattering how it occurs?
Thanks xiyangxixia can you elaborate the term the scope of energy level?
Roughly speaking, impurities can cause the electron to become trapped, bouncing between different impurities. Making this precise was Anderson's Nobel prize. If you are well versed in field theory, Ben Simons (google for him) has a couple of good sets of graduate lecture notes on his website.
Thanks genneth for such a nice favour :)
how to separate real and imaginary parts of a complex number??
i read that real and imaginary parts of a complex number can be separated by following equation
1/x+iη=P(1/x)-iδ(x)
where P is principal of x i dunt understand this equation can any 1 explain this?
It is the Cauchy principal value. See http://www.damtp.cam.ac.uk/user/stcs/courses/fcm/handouts/cauchy_principal_value.pdf for some notes.
Your equation is meant only in a distributional sense, i.e. they give the same thing if you integrate them with a test function.
1/x+iη=P(1/x)-iδ(x)
the simplest example is if you have
\int \frac{f(x)}{\text{i$\epsilon $}+x} \, dx
so sometimes it is usefull to rewrite it in way
\int \frac{f(x)}{\text{i$\epsilon $}+x} \, dx=P \int \frac{f(x)}{x} \, dx-i \pi f(x)
where P means that you integrate in terms of principal value
  • · Replies 0 ·
