Find Continuity of f_α Along Negative X-Axis
  • Thread starter Thread starter Samuelb88
    Branch
The discussion focuses on finding a continuous branch of the square root function w=z^{1/2} along the negative x-axis. The principal square root function, defined as |z|^{1/2} (cos(θ/2) + i sin(θ/2)), is established as discontinuous along this axis. A new branch f_α(z) is proposed, where α < θ ≤ α + 2π, to address this discontinuity. The participant concludes that selecting α=0 shifts the discontinuity to the positive x-axis, clarifying the approach to the problem.
  • Understanding of complex functions and their branches
  • Familiarity with the principal square root function in complex analysis
  • Knowledge of polar coordinates in the complex plane
  • Concept of path dependence in limits
  • Explore the properties of branch cuts in complex analysis
  • Study the implications of choosing different values for α in branch definitions
  • Learn about continuity and discontinuity in complex functions
  • Investigate the behavior of limits in the context of complex variables
Students and professionals in mathematics, particularly those studying complex analysis and seeking to understand continuity in multi-valued functions.
Samuelb88
Find a branch of [itex]w=z^{1/2}[/itex] which is continuous along the negative x-axis.
The book proves that the principle square root function [itex]|z|^{1/2} \big( \cos(\theta/2) + i \sin(\theta/2) \big)[/itex], where [itex]-\pi < \theta \leq \pi[/itex] is discontinuous along the negative x-axis.
I've defined a new branch of the square root function [itex]f_\alpha (z) = |z|^{1/2} \big( \cos(\theta/2) + i\sin(\theta/2) \big)[/itex], where [itex]\alpha < \theta \leq \alpha + 2\pi[/itex]. I know the principle square root function is discontinuous along the negative x-axis because the limit as the principle square root function is path dependent as [itex](r,\theta)[/itex] approaches an arbitrary negative number [itex]r_0 e^{i \theta_0}[/itex]. What's the best way to proceed from here? Should I choose an [itex]\alpha[/itex] such that [itex]f_\alpha[/itex] can only approach the negative x-axis one way?
There's a lot of choices for alpha. Why not pick alpha=0? Where is the discontinuity now?
Along the positive x-axis. I understand how I should approach the problem now. Nonetheless, thank you for your help! My book hid the fact that branches are discontinuous along their branch cuts at the end of an example.
  • · Replies 22 ·
  • · Replies 40 ·
