Conservation of Momentum puzzle
The discussion revolves around the implications of Maxwell's Equations on the Law of Conservation of Momentum, particularly in the context of a thought experiment involving electromagnetic fields and their interactions with devices in space. Participants explore theoretical scenarios and the behavior of magnetic fields, questioning the assumptions and interpretations of momentum conservation in these contexts.
  • One participant proposes a conflict between the creation of magnetic fields and the speed of light limit, suggesting it challenges the Law of Conservation of Momentum.
  • Another participant asserts that Maxwell's equations always conserve momentum, referencing a previous discussion for support.
  • Some participants highlight the importance of considering the momentum of the electromagnetic field itself in the context of the proposed device.
  • Concerns are raised regarding the assumption of an infinitely rigid device, emphasizing that changes in velocity must propagate over time in special relativity.
  • A thought experiment is presented involving two coils in space, exploring how the momentum of the magnetic field leads to different outcomes based on the orientation of the coils.
  • A later post questions the expression for the momentum of an electromagnetic field and how it differs in the scenarios described.
Participants express differing views on the implications of electromagnetic fields on momentum conservation, with no consensus reached on the validity of the proposed conflict or the interpretations of the thought experiments.
Participants note limitations in assumptions regarding the rigidity of devices and the propagation of changes in velocity, as well as the need for clarity on the momentum of electromagnetic fields in different scenarios.
One key aspect of Special Relativity is the fact that nothing can travel faster than the speed of light. This concept derives from Maxwell's Equations, which calculate the speed of light (electrodynamics). Since Maxwell's Equations describe the formation of magnetic fields (as a result of moving electric charges), I propose a potential conflict in the creation of magnetic fields and the speed of light limit on the movement of those fields through open space (vacuum). This conflict challenges the Law of Conservation of Momentum. The thought experiment illustrating this conflict is a bit too long to present in a post, so I have presented it in the attachment.
This is incorrect, Maxwell's equations are guaranteed to always conserve momentum:
http://farside.ph.utexas.edu/teaching/em/lectures/node91.html
See the exchange between Tominator and myself starting with his post 40 where he proposes a device like yours and works through the implications:
https://www.physicsforums.com/showthread.php?t=287164&page=3
Like Tominator in the thread that DaleSpam linked to, you are not taking into account the momentum of the electromagnetic field.
You are also assuming the device is infinitely rigid, which in special relativity is not possible. You speak of "the velocity of the device" changing immediately due to a force on one end. But in fact a velocity change will require time to propagate from one end to the other.
Lots of good information here.
Let me see if I can summarize. The battery sends energy to the coil to create an electromagnetic field. The energy given up by the battery is stored in this field and the field expands away from the coil at the speed of light. If an object or device captures a portion of this energy, the momentum associated with that energy portion is transferred to the object or device.
Put another way, if the device I described was sitting out in space and the device was made to work as I described, then the device would start moving as I described. The momentum gain of the device is offset by the momentum of the remainder of the field energy that wasn't captured by the device. It would be an engine for a space vehicle.
I don't know if it would work exactly as you described, I only skimmed the document enough to recognize the parallels with Tominator's proposal. But you could indeed make a (very inefficient) space propulsion system this way. But you would be far better off just shining a flashlight.
Suppose there is a coil and battery sitting in open space, which will be called Coil Device One. The battery is turned on for a short time, then turned off. Now there is a magnetic field expanding around Coil Device One and this field moves outward. The total momentum of the system is zero because the field is symmetrically distributed and expanding everywhere at the same velocity. Sitting away from Coil Device One is Coil Device Two, directly in line with the North pole of Coil Device One. Just before the magnetic field reaches Coil Device Two, it is switched on. Coil Device Two is oriented so that its North pole is in line with Coil Device One. When the magnetic field reaches Coil Device Two, it is repelled and moves away from Coil Device One.
A second experiment is just as described for the first experiment above, except this time Coil Device Two is oriented so that the South pole faces the North pole of Coil Device One. In this experiment, when the magnetic field reaches Coil Device Two, it is attracted by this field and moves toward Coil Device One.
In both experiments, the momentum of the field generated by Coil Device One is exactly the same. But in the first experiment, the momentum of Coil Device Two is directed away from Coil Device One and it the second experiment, the momentum of Coil Device Two is directed toward Coil Device One. How does the momentum of a magnetic field explain these two different outcomes?
From the first link in post 2, what is the expression for the momentum of an EM field? How does that differ in the two cases?
  • · Replies 26 ·
  • · Replies 33 ·
  • · Replies 36 ·
10K
  • · Replies 35 ·
