Calculating Piston Ring Twist Analytically
  • Thread starter Thread starter hartbreikkid
    Piston Ring
This discussion focuses on the analytical methods used to calculate static twist in piston rings, emphasizing the importance of understanding the elasticity of the metal involved. While various papers reference analytical tools for this calculation, a detailed explanation of the methodology is often lacking. The conversation highlights the necessity of consulting experienced application engineers from piston manufacturers to optimize ring packages for performance, particularly in racing applications. Practical insights include the balance between combustion chamber sealing, minimizing ring drag, and effective oil control.
  • Understanding of piston ring mechanics
  • Familiarity with elasticity principles in materials
  • Knowledge of combustion engine performance optimization
  • Experience with application engineering in automotive contexts
  • Research analytical methods for calculating piston ring twist
  • Explore the elasticity of materials used in piston rings
  • Investigate optimal piston ring packages for racing applications
  • Learn about the role of application engineers in piston design
Engineers, automotive performance specialists, and racing enthusiasts seeking to enhance piston ring performance and understand the analytical methods behind piston ring twist calculations.
hartbreikkid
Hi,
I have found many papers using analytical methods to calculate the static twist in piston rings. All the papers that i found have used the results of that analytical tool but no one explained how the tool works. Can anyone find a paper in which the analysis to calculate piston ring twist is explained.
Thanks in advance.
The tool you are thinking of relates to elasticity of the metal piston ring I believe.
The attached pdf tells more than I will ever know about this. All I can add is that you need an experienced application engineer when working with the various piston manufacturers. A lot of hot rodders and racers have spent a whole lot of time doing destructive testing over the years to come up with the optimum ring package to control oil and provide the best combustion seal. All kinds of trick stuff. We ran zero gap rings one year..for our application it was NOT the hot set up. it all depends on balance and trade offs. You need the max combustion chamber seal with minimal parasitic ring drag and the best oil control yet still cool the bottom of the piston.
Unless you are breaking new ground on this, talk to the application guys at the manufacturers.
  • · Replies 45 ·
