SyntheticVisions
- 5
I'm having some trouble with a few problems involving derivatives and rates. Here's one of the ones that is confusing me:
A waterskier skis over the ramp shown in the figure at a speed of 30ft/s. How fast is she rising as she leaves the ramp?
The ramp is a right triangle facing the waterskier so that they can go up it, with sides of (assume y is the vertical axis, x is horizontal, z is hypotenuse) x = 15ft, y = 4ft, and by the pythagorean theorem, z = [tex]\sqrt{241}[/tex]
The first problem I was having here, is whether or not the speed given is relative to the x axis, or the z axis? I would think generally the x axis, but the problem states "over the ramp". Also, when doing the problem for the speed given on the x-axis I got a negative number for dy/dt. When doing it given on the z axis I get about 116ft/s, which seems too fast.
Assuming it's on the x I set it up like so (I wasn't sure if I should use z^2, but I don't know what dz/dt is so I didn't...):
[tex]x^2 + y^2 = \sqrt{241}[/tex]
[tex]2x \frac{dx}{dt} + 2y \frac{dy}{dt} = 0[/tex]
[tex]900 + 8 \frac{dy}{dt} = 0[/tex]
[tex]\frac{dy}{dt} = \frac{-225}{2}[/tex]
Which doesn't make any sense. Where am I going wrong here?
