Can the Double Slit Experiment Be Conducted with C60 Molecules?
The discussion explores the possibility of conducting the double slit experiment with systems other than light, specifically considering the use of C60 molecules, also known as "Buckyballs." The scope includes theoretical and experimental aspects of wave-particle duality in various systems.
  • Exploratory, Experimental/applied
  • Some participants suggest that the double slit experiment can be performed with various systems beyond light, including water waves and sound waves.
  • Participants mention that experiments have been conducted with electrons and atoms, indicating a range of applications.
  • One participant introduces the idea of using C60 molecules in a multiple slit experiment, noting their size and composition as significant factors.
  • A link is provided to further information about experiments involving C60 molecules, suggesting ongoing research in this area.
Participants generally agree that the double slit experiment can be conducted with different systems, but there is no consensus on the specifics of using C60 molecules or the feasibility of such experiments.
The discussion does not resolve the technical details or limitations of conducting the double slit experiment with C60 molecules, nor does it clarify the conditions under which such experiments would be valid.
Readers interested in experimental physics, wave-particle duality, and the applications of quantum mechanics may find this discussion relevant.
4everlonging
can the double slit experiment be performed with systems other than light?
Yes. Some of them even at home.
Make a double slit of carton (slits 1cm wide, separated by 10cm), install it in your bathtub, and play with water waves.
Make a double hole in a sheet of rubber foam and play with sounds generated by small loudspeaker.
...and some experiments demanding more serious lab: with electrons, or even atoms.
@xts that is really cool
Also electron beam. That's quite interesting.
thanks
Although not a for a double slit you may find this interesting:
You can observe interference if you shoot C60 molecules at a multiple slit. The "Buckyball" molecules consist of 60 carbon atoms, so quite big molecules.
http://www.univie.ac.at/qfp/research/matterwave/c60/index.html#links"
  • · Replies 24 ·
  • · Replies 20 ·
  • · Replies 36 ·
10K
