Acceleration of two bodies in circular orbit provided by own gravity
The discussion focuses on calculating the radius of circular orbits for two bodies influenced by their mutual gravity. The key formula for velocity in circular orbits is established as vo=sqrt(GM^2/ro). The centripetal force acting on the outer body is equated to the gravitational force, leading to the equation m1*m2/dist^2 = m1v^2/r. The concept of "reduced mass" is introduced as a method to simplify the problem by treating the two-body system as a single effective mass orbiting around the center of mass.
  • Understanding of gravitational forces and centripetal motion
  • Familiarity with the concept of reduced mass in physics
  • Knowledge of circular motion equations and their applications
  • Basic algebra for manipulating equations
  • Research the application of the reduced mass concept in two-body problems
  • Study gravitational interactions in multi-body systems
  • Explore advanced topics in orbital mechanics, such as perturbation theory
  • Learn about numerical methods for simulating orbital dynamics
Students and professionals in physics, astrophysics, and engineering, particularly those interested in orbital mechanics and gravitational interactions between celestial bodies.
Ry122
If two bodies are moving about a common point, with one orbiting the other, in a completely circular orbit, from knowing just their periods (which are equal) and the graviational constants of each body times mass, how would you determine the radius of each of their circular orbits?
You can get the velocity as a function of the period and radius.
And for circular orbits vo=sqrt(GM^2/ro)
But since the inner body's position is constantly changing you can't straight forwardly apply the above equation to the outer body can you?
And for the inner body it would be in circular rotation about a point below its surface, so I'm not sure how you would apply the equation in that situation.
Astronomy news on Phys.org
I came up with this idea. Would it work?
centripetal force on outer body = m1v^2/r
Force due to gravity = m1*m2/dist^2
force due to gravity will be equal to the centripetal force since it's in circular motion so
model dist between object one and two as a function of their masses (with centre of mass equation) to reduce to a one variable function and solve for r
Yes, that is just what you want to do. After you've solved it that way, look up how the concept of "reduced mass" can be used to replace a problem with two masses with an effective problem that is a lot simpler because it just has one effective mass going around in a circle with a radius of the distance between the real masses, rather than the actual outer mass going around the center-of-mass as you correctly describe the situation. Replacing the real problem with that effective problem does all the tricky arithmetic for you, but you should do it your way first to verify that it works.
  • · Replies 86 ·
9K
