Momentum of ball bouncing off wall
The discussion revolves around a racquet ball's momentum change during a perfectly elastic collision with a wall. The problem involves calculating the change in momentum given the ball's mass, initial velocity, and angle of impact.
  • The original poster attempts to determine the change in momentum using initial momentum calculations and questions whether to apply the impulse-momentum theorem or kinematics for acceleration.
  • Some participants suggest considering the conservation of kinetic energy due to the elastic nature of the collision.
  • Others note the importance of recognizing momentum as a vector, highlighting how components of momentum behave differently upon collision.
aszymans
A racquet ball with mass m = 0.247 kg is moving toward the wall at v = 12.4 m/s and at an angle of θ = 32° with respect to the horizontal. The ball makes a perfectly elastic collision with the solid, frictionless wall and rebounds at the same angle with respect to the horizontal. The ball is in contact with the wall for t = 0.063 s.
What is the magnitude of the change in momentum of the racquet ball?
I found the initial P already and am not sure if I should use the (delta)P= F(net)* (delta)t and use 1-d kinematics to find acceleration or how exactly to begin.
Since the collision is assumed to be perfectly elastic, try using conservation of KE.
Then find the change in momentum.
Momentum is a vector quantity. The component of momentum parallel to the way will not change. The component of momentum perpendicular to the way is multiplied by -1.
14K
